Go Back   Home > Forums > Amplifiers > Class D
Old 25th June 2004, 08:21 AM   #31
Bricolo is offline Bricolo  France
Bricolo's Avatar
Originally posted by phase_accurate
So why not ?
because I want something simple. Like a class d chim amp
Old 25th June 2004, 09:09 AM   #32
There's a new chip by philips (TDA.... something), that contains comparator, drivers and powerstage. With this one it should be possible to build a minimalistic UCD maybe.
What does Bruno think about this ?
Charles
Old 25th June 2004, 09:15 AM   #33
then your best bet would be something like that. You get real McCoy UcD for 60 Euro IIRC.
Best regards,
Jaka Racman
Old 25th June 2004, 09:29 AM   #34
Bricolo's Avatar
Charles
do you remember the "something" ?
Best regards,
Jaka Racman
I'm looking for something quick n cheap. 60€ (+S&H) *2, plus transformer, plus caps, plus filter....
I'm now seriously thinking about usung National's chip, even if it's not as powerful as I would like. For the momment that's the closer I found, from quick n cheap
Old 25th June 2004, 09:56 AM   #35
if there was a "cheap, quick and dirty" way of doing class D, you would see more of it. Here is the link for TDA... , but you would need to do PCB for it. I will not say that P2P approach is not possible, but you would have to know exactly what are you doing, which are the loops that must be keep tight, how to implement proper grounding, etc. You will also learn that switching circuits have a very fragile barrier for Magic Smoke which is enchanted into components during manufacture to make them work. IMHO 60 Euro is cheap for ready made module, which is guaranted to work. Power supply costs will be the same whatever path you take.
Best regards,
Jaka Racman
Old 25th June 2004, 10:23 AM   #36
Yes that is the "something" I meant. In the meantime they even have a better datasheet online. But there is still no data about availability, pricing etc.
Charles
Edit: This would give a nice "Switchclone".
Old 25th June 2004, 10:35 AM   #37
Bricolo's Avatar
Thanks for the link,
If I understood the datasheet correctly, I need another chip to drive the TDA8939 (a PWM controller), right? So I can't directly feed the inputs with an audio signal
Old 25th June 2004, 11:02 AM   #38
I think you should read Bruno's comments on the chip in the UcD Mueta thread. Maybe it would be possible to use both halves paralelled in dual supply configuration and make UcD type amplifier with built in comparator. Another approach would be to use single supply and one of the TI small filterless class D chips as modulator and TDA as power output stage.
Best regards,
Jaka Racman
Old 25th June 2004, 11:08 AM   #39
Because this thingie
1) can be used with symmetrical PSU and
2) has a built-in comparator
it should be possible to make something like an UcD.
Charles
Old 25th June 2004, 11:34 AM   #40
Bricolo's Avatar
There seem to be lots of duscussion about UcD
Hasn't anything be built yet? I saw some redults (distortion measurements...) but no photo/schematic or pcb.
Soft start for class AB VMat Solid State 14 13th June 2011 09:04 PM
beginner advice for a place to start pharsyd Class D 1 13th January 2006 01:44 AM
Complete beginner; looking to start. kartoffel Solid State 4 11th October 2004 08:20 AM
Class A repair : where to start ? neototem Solid State 5 6th September 2004 10:41 AM
Page generated in 0.12526 seconds (80.02% PHP - 19.98% MySQL) with 10 queries
