Go Back   Home > Forums > Amplifiers > Class D
Home Forums Articles Gallery Blogs Register Donations FAQ Calendar Search Today's Posts Mark Forums Read
Thread Tools
Old 24th January 2007, 01:04 PM   #131
Workhorse's Avatar
Send a message via Yahoo to Workhorse
Hi Choco,
What happened to your project?
regards,
K a n w a r
The Power Fanatic
Old 28th January 2007, 10:35 AM   #132
Hi Kanwar,
I opened my thread about my babysteps of my Class D Rookie... Well... had some drawback, because I fried my hard disc by a short circuit from my 2kVA PSU ==> USB scope ==> internal GND of notebook ==> hard disc ==> enclosure of hard disc ==> screw at hard disc cover ==> metal rack on which the notebook was standing (while I thought it would be floating well isolated... ) ==> PSU...
OK, only the hard disc was fried, all the rest of the notebook seems to fine. ..running again.
I went on and since about one month I am strugling with the weaknesses of the IRS20954S. It is oversensitive vs noise. I managed to get it working up to something about 40A..50A even with the noise at hard switching conditions. But I wanted to have proper operation up to 60A..70A (did not work out so far) and then set the current limit to 55A. Furtheron the IC can be killed by the MosFets reverse capacity. I was able to cure this by an external driver.... STOP !!! Too many work arounds and still no satisfying behaviour. I think now I know why IR does promote this IC just for 200W, while the voltage rating and 1A driver capability in the data sheet would indicate to use it also in higher power amps...
I am right now changing my concept to:
Hysteresis resonator + level shift towards neg rail + IR2113 halfbridge driver + discrete shut down circuit
Will post the new schematic soon in my babystep thread.
Bye
Markus
Old 28th January 2007, 02:33 PM   #133
Workhorse's Avatar
Originally posted by ChocoHolic
Hi Kanwar,
Bye
Markus
Hi Markus,
Thats good,
IR2110/2113 is wise solution and much robust as its the industrial workhorse of many offline smps...as well as Class-D amps
waiting to see your schematic,
K a n w a r
The Power Fanatic
Thread Tools
line-array vs conventional point-source/ distorsions issues crazyhub Multi-Way 26 2nd July 2007 12:03 AM
How about a round-up of Class A kit power amps, or collectable vintage class A? Brisso57 Solid State 4 14th February 2007 10:30 AM
Class D Vs Class I (Balanced Current Amplifier) rmsaudio Class D 28 29th September 2006 07:03 AM
Zen v4 and bass distorsions ... Stabist Pass Labs 4 24th September 2002 11:59 PM
Page generated in 0.06770396 seconds (76.38% PHP - 23.62% MySQL) with 11 queries
Copyright ©1999-2010 diyAudio
