class A amp with switchmode psu??? - diyAudio
Go Back   Home > Forums > Amplifiers > Class D
Old 17th June 2004, 07:17 AM   #1
Default class A amp with switchmode psu???
is it possible to have a class A amp, with a switchmode psu (if the output of the psu is put through a linear regulator to minimise ripple)...i was thinking of using the lm2575 type switching regulator...is it possible to get 60V out of this chip..ideas would be much appreciated..
Old 17th June 2004, 08:31 AM   #2
Ouroboros's Avatar
A 2575 (or the higher frequency 2595) won't go this high in voltage. There aren't many buck converters with built-in switching transistors that are designed for high-voltage operation.
With a competantly designed switcher you won't need a linear post-regulator but you will need decent filtering on the output.
As a class-A amp (by definition) draws a steady current from the PSU, do you really need a regulated supply?
Old 17th June 2004, 11:52 AM   #3
bigparsnip's Avatar
Default Re: class A amp with switchmode psu???
What would be the poin tof using a switchmode power supply (used mainly for their efficiency and PFC abilities) if you are then going to ruin the efficiency of the supply (or feed a class-a amp from it for that matter) by using a linear regulator after it.
Surely in this case it would be a lof simpler,safer and cheeper in the end yo simply go with the traditional power supply for your project?
Switchmode on the WWW TroelsM Power Supplies 9 10th April 2009 11:08 AM
Switchmode Transformer nitrate Car Audio 60 10th November 2008 11:47 AM
Class AB car amp, switchmode power supply, what rails?? SkinnyBoy Solid State 4 8th December 2003 03:26 PM
Switchmode B+ PSU richwalters Pass Labs 0 26th September 2003 09:20 PM
Copyright 1999-2017 diyAudio
