Class D preamp ??
Class D preamp ??
Old 12th March 2009, 07:17 PM   #41
Workhorse is offline Workhorse
Workhorse's Avatar
Originally posted by Pafi
Of course its possible. But why?
why Not
Old 12th March 2009, 07:37 PM   #42
dmfraser is offline dmfraser  United States
Default Class D preamp
Since class D is essentially an on-off representation of an audio signal and could be a pulse code modulation as well, would this not just be a DSP then.
Because Class-D's big selling point is greater efficiency and since a pre-amp is very low power anyway, there is no reason to make class-D op amps for a pre-amp.
I have been working with 24 bit 96K DSPs for long enough now to know that this will work better than any simulation of an op-amp with a PWM method. And I normally pull 100db of dynamic range from the A/D converters I use.
With the AES/EBU or S/PDIF inputs on my DSP and with the digital studio systems as well as the I2S to PWM modulators made, it is now possible to have a fully digital path from the mic preamp in the studio right up to the power output stage in the power amp.
I am doing this now with D2Audio Modules and will be expanding it into other power amp technologies soon.
Dan Fraser
Class D preamp ??Hide this!Advertise here!
Complementary Class A Preamp using BC368-369 lineup Solid State 20 22nd September 2016 11:27 PM
DIY Class-A mic-preamp AudioAngel Solid State 15 4th December 2009 04:28 PM
Passive Preamp With Class-D JimOfOakCreek Class D 10 23rd July 2007 03:35 PM
Class A SET preamp, help cukkurullo Tubes / Valves 1 28th May 2006 07:10 PM
my class a preamp evilspirit Solid State 10 30th June 2004 08:17 PM
Copyright ©1999-2017 diyAudio
