Success with class-d? Success with class-d? - Page 2 - diyAudio
Old 26th May 2004, 06:02 AM   #11
IVX is offline IVX  Russian Federation
IVX's Avatar
U cant synchronise multiple Self-Oscillating Class-D amps
Why do you think that ZeroTHD can't do it? Candid camera again is ON?
Best regards,
E1.
Old 26th May 2004, 09:38 AM   #12
ZeroTHD is offline ZeroTHD  Sweden
The reason is simple , U cant synchronise multiple Self-Oscillating Class-D amps to a common SWitching frequency.
"Can not" is a strong combination of words...
As I told you before- I'm new to this business, but do I really need to synchronise the switching frequencies? I guess you mean that i.e. the left and the right channel wouldn't oscillate at the same frequency. Do they have to? Can you notice if they differ a few percent?
Anders
Old 26th May 2004, 11:09 AM   #13
phase_accurate is offline phase_accurate
A few percent could indeed be even worse than a large difference ! This is because they might cause intermodulation products. This all depends on construction, PSU decoupling etc.
Charles
Old 26th May 2004, 12:26 PM   #14
I guess this would be a problem even in non-self-oscillating designs as long as it runs from separate tri-wave generators. The problem should be solved by minimzing the coupling between the two channels (by distance and by proper PSU design).
Right now I'm having problmens with shoot through. I'm not sure if this is because of imbalance in the circuit, or if I need to incorporate some dead time circuitry.
This is getting interesting!
Thanks,
Anders
Old 26th May 2004, 02:49 PM   #15
Jan-Peter is offline Jan-Peter  Netherlands
Hi Anders,
The routing of the PCB is very importend to avoid coupling of between multichannel Class-D.
Please post your schematic perhaps the forum can give you some idees for decreasing the shoot through problems.
Jan-Peter
www.hypex.nl
Old 26th May 2004, 04:27 PM   #16
Remember, I'm new to this, so don't be too hard on me.
Regarding choice of components. I picked components I have on the shelf for easy and cheap prototyping.
Thanks,
Anders
Old 26th May 2004, 06:34 PM   #17
IVX's Avatar
hmm, i haven't problems with shoot through in this simulation (MC7), but with si4480 (haven't 4484 model).
Jan-Peter,
BTW, in UcD 180 sync. input doesn't exist???
Best regards,
E1.
Old 26th May 2004, 07:03 PM   #18
Pabo is offline Pabo  Sweden
ZeroTHD
You cannot measure THD in the simulation program without lowpassfiltering extremely hard because of the same reason that you lowpass filter a signal before A/D conversion. My own classD amplifier measures 0,0008% at 1kHz 1W with AP but shows 20% or so in a simulation. Even with third order low pass filter after the second order output filter the simulation shows about 0,5% or so. Donīt really kno why.
In order to reduce shoot through, make sure that the turn off transistor that you use is a high beta type with large bandwidth. If the bandwidth is too low the beta will drop, maybe down to unity, at the switching speeds you are trying to obtain. You will allways have some shoot through though, otherwise the distorsion will increase.
If something that measures good doesnīt sound good, measure again!
Old 26th May 2004, 07:05 PM   #19
A good choice by the way is BCX-56 or something like that??
Old 26th May 2004, 07:15 PM   #20
IVX,
No there is no seperate sync input on the UcD180.
I don't have experience with synchronisation but I guess you can try to mix the HF signal together with the input. As far as I understand the UcD will then synchronize to this HF signal.
We use a NE5532 as symmetrical gainstage with a gain of 5x. So the HF signal must pass also the NE5532.
I don't know if this work, anyway I haven't tried it yet.
ZeroTHD,
Did you actually build a physical module for testing?
Jan-Peter
www.hypex.nl
Success with class-d?Hide this!Advertise here!
simple se success! newtube Tubelab 3 24th May 2009 09:23 PM
TDA7560 car amp, second try, success! Redshift187 Chip Amps 6 22nd September 2008 11:48 AM
First Re-Cap Success ! ! 65blkbkgt Car Audio 9 11th July 2007 07:47 AM
Copyright ©1999-2017 diyAudio
