| Class D Switching Power Amplifiers and Power D/A conversion |
#11 |
I mean Inductance of course, i'm sorry..
Best regards, E1. |
#12 |
ChocoHolic - your right on the mark - I want to get fairly good power rails to run a stero off a car battery (while running of course, so hence the 14V). The problem was that I was using fiarly simple measurements - the DC power supply gives a needle voltage and amp reading - but I was running it in the lower end of its capababilities (can supply 48V @ 50A). But I'm pretty sure it was in thermal steady state after 10mins.
Well as for finding a chunky resistor that can handle the jandle - didn't happen (at 0.015 ohms @ 18A its still 5W). However I did manage to locate a clamp-on DC current meter that plugs into a scope - give 100mV per Amp. I didn't have time today to get read outs, but I'll get onto it and narrow down the problem. I'll even post up sexy waveforms straight from the o'scope. If the primary inductance does prove to be the problem I'll crank up the frequency by changing a cap or a resistor... Ready to be shocked? I'm using a 555 to generate the timing and a couple of comparators to get the right duty cycle to drive the FETs (though some BJTs). It is working quite well though - they both have the same duty cycle +- 0.1% - so there shouldn't be any serious flux walking - and if there was I'd just have a heater wouldn't I? Also for posting pictures - do I have to host them and link them in or is there somewhere I can upload them to? I can host them if that is the case - but its hard to stick stuff on and my websever isn't really the most reliable of creatures. I'll get them up here in a couple o days - I've got some to do tomorrow.
#13 |
Is the topolgy kind of an half bridge?
What kind of ETD49 with 3c90 are you using, is there an airgap at the center legg?? just 4 turns with that ferrite material I strongly suggest you to find the correct switching frequency which is for sure much higher than 21 kHz. Cheers
"If transistors are blueberries and FETs are strawberries, then tubes must be.. pears" Michael 29th January 2010 |
#14 | ||||
Last of all -> IME many digital meters go nuts if you feed high frequencies into them. You might not be measuring anything like the correct amps.
#15 | |
Around ten years ago i'd made such, but now usual tl494. BTW, how much value of gate resistors?
Best regards, E1. |
#16 |
Just in order to make sure that I am on the right track...
I estimate your SMPS is a similar topology to this: http://sound.westhost.com/project89.htm Right? Then the primary inductance is not of major importance. You are using an ungapped core right? Your primary is 2x4turns center tapped? Then it is fine. You will not have any issues with saturation at 21kHz. Swing of flux density will run between +/- 150mT. deltaB = (U x Ton) / (N x Ae) = (14V x 17.9µs) / (4 x 210 E-6 m^2) = 0.3T = 300mT =+/-150mT If you increase the frequency you will probably not get a benefit, without adjusting the entire design. ...from all your description my feeling is that your circuit works better than your measurement I partially agree to Circlotron. Especially his last comment. Because of this my proposal was to measure the DC values after a simple filter. But you do not need to try decrease the losses in components which remain cool. If your MOSFETs are cool then they do not have much losses. Are you sure that the turn on/off time is really 0.5µs? Is this the speed of the voltage sloping or the current sloping??? Well, who cares. If they are cold, they are not lossy. Good luck Markus |
#17 |
....found your schematic in your older thread.
OK, it matches to what I had expected. |
#18 |
Another point, but it does not look like you are
struggling with this. Symmetry of push/pull duty cycle very important in this circuit. Already small unsymetries will run your transformer into saturation.... Furthermore the data sheet of your core material: http://www.elnamagnetics.com/library...ok/mat3c90.pdf |
#19 | |
Well there's my intuition, I'm just used to much higher voltage when talking SMPS, should have done the math too, shame on me! But I am not sure about your saying it's +/- 150 mT, it's in my opinion +/- 300 mT, it's push pull action. If switching frequency is 21 kHz then we have in reality 42 kHz since upper and lower FET's are switching with 180 degree phase shift. So the 17,9 uS you stated is actually 75% duty cycle, eg. there's 25% time left until the opposit FET is switching, right...?! When saying 75% duty cycle I mean that 75% percent of the time window is used until the opposit FET is switching, just in case so we don't rise a semantic question what duty cycle is because at the moment I must admit i don't remember how it's defined for a half bridge topology. At 100 degrees 300 mT is maybe a bit too much, so either should the frequency be a bit higher or duty cycle a bit lower if we will experience high temperature, which hot runing equipment might be possible to reach in a car at summer time... The core is saturating earlier at high temperature and the current running through the switching FET's is increasing with hotter FET's as a result etc. Cheers
#20 |
I think 37.5% is the percentage of the full period.
Period is 47.6us at 21kHz. So ON-time would be 17.86us. Then there is duration of about 6us while all MOSFETs are off. After the opposite MOSFET will turn on. The first MOSFET was "pushing". The second MOSFET now is "pulling" which means that the it will pull also the flux density to the other direction. Of course in the beginnig until steady state is reached the flux density may not be symmetrical to zero, but shifted. After some time the it will balance (if both cycles are really symetrical !!). Some PWM-chips provide a soft ramp up of the duty cycle in order to avoid saturation issues during start up. I am just thinking little more.... May be that the 37.5% duty cycle is only the duty cycle of the current. The voltages across the winding may act different. Probably they will make 50/50 cycle. Which means that our flux density would ramp between +/-200mT in steady state. I estimate the 50/50 duty cycle of the voltages across the windings because the following: First MOSFET was ON and will be turned OFF: Now all MOSFETs are OFF. Due to the law of induction the voltage across the windings will reverse the voltage up to any clamping voltage or defect of isolation. In our circuit it will be clamped by the secondary windings and the output caps, if coupled perfectly. The voltage across the switch which was turned OFF last will jump to 2x14V=28V (I think). The voltage accross the other MOSFET will jump to zero. A real transformer may have some leakage inductance and cause some voltage peaks at the MOSFETs. Probably some snubber would be a good idea! The voltage across the winding should jump from +14V to -14V. The stored energy in the inductor will decrease, but before it reaches zero the second MOSFET will be turned ON. Uhps, that's great! This means turn ON is a Zero Voltage Switching! So switching losses will only happen during turn OFF for the switches.... Hm, and these turn OFF losses you can probably avoid by the same snubber which you should use anyway against voltage peaks. ...start liking this circuit, I will go to simulation and revert..... Bye Markus P.S. 3C90 can handle slightly more than 300mT at 100°C without saturation. |
| 8" high efficency woofers - NEED HELP | Miha | Multi-Way | 9 | 28th February 2007 01:43 PM |
| Efficency Confussion | Mutley666 | Multi-Way | 10 | 25th May 2005 02:15 AM |
| Passive crossover (in)efficency? | Pbassred | Multi-Way | 6 | 12th May 2005 12:34 AM |
| Few SMPS issues | arcom | Car Audio | 9 | 30th January 2005 12:55 PM |
