Class D amp - Page 2 - diyAudio
Go Back   Home > Forums > Amplifiers > Class D
Old 28th April 2004, 02:51 PM   #11
sonu is offline sonu  India
Default Class D amp
Thanks,
can you please refer to any website for the PCB layout.
Old 28th April 2004, 09:05 PM   #12
Ryssen is offline Ryssen  Sweden
Ryssen's Avatar
Did a serch maybe there is something there http://www.google.se/search?q=AN9525...%B6kning&meta=
Im interested to.
Old 29th April 2004, 12:36 AM   #13
Ryssen's Avatar
http://www.intersil.com/support/dist...n=HIP4080AEVAL
Old 30th April 2004, 02:25 PM   #14
Default Class D
The links you mentioned, they have no stock for Evaluation Boards.
Anybody there who could help in getting a Evaluation board,
----OR----
Postscipt, Gerber Files of the PCB.
I am very desparate to get it working & getting good performance from these cool Amps Design.
ANYBODY THERE.
Old 30th April 2004, 05:07 PM   #15
diyAudio Moderator Emeritus
lumanauw's Avatar
Send a message via Yahoo to lumanauw
HIP4080 is quite choosy with mosfets. I've tried with IRF540, but failed. Maybe the input cap is too big. Try other/newer kind of mosfet, with lower input cap. I've tried with FDP mosfets, and works fine.
There will be always little noise/hiss, and DC offset. Usually can be made minimum, but cannot eliminate them.
It seems Intersil cant (or wouldnt) give as much support, as they have sell the technology to Behringer.
Old 30th April 2004, 05:41 PM   #16
Default PCB
You cannot very easily make a quiet class D amp on a single sided board. I found ground planes are very important for quiet operation. The B&O mdules i use are done with a 4 layer PCB to get the 115db S/N ratio they have.
Also, the HIP4080 IC has a primitive single comparitor modulator that is not particularly good. Whie it is a decent FET driver, the quality of the modulator means that you have to either use an external modulator or you use this amplifier just as a sub-woofer amplifier. Many class D car amps, like Kicker use the 4080 in the sub channel but class B for the other channels.
There are some class D amp schematics available at:
www.schematicsforfree.mattsoft.net
Dan Fraser
Old 30th April 2004, 07:20 PM   #17
Ryssen's Avatar
I have ordered a couple of samples of HIP4080,but I could not get a hold of any HIP2060 the N chanel,halfbrigde Power MOSfets that they have,does anyone have a schema with IRF540 or FDP mosfets,Whatever they are?And what is the output with these,I am going for a sub amp for my computer or iRiver.By the way if I happend to get a hold on HIP2060 what would the outputpower be?
Old 1st May 2004, 07:57 PM   #18
bknauss is offline bknauss  United States
Send a message via AIM to bknauss
Why not go for the HIP4081 and have independent control over all of the FETs?
I can tell you from experience that doing a buck converter (very similar to a Class D design) is fussy on vero board.
1500W RMS Class D PCB - which Class D Driver Chip is it ? mosfetsound Class D 11 1st April 2011 12:17 PM
Can a Class AB PP amp be said to be operating in Class A at low signal levels? ray_moth Tubes / Valves 19 23rd January 2009 08:52 PM
How about a round-up of Class A kit power amps, or collectable vintage class A? Brisso57 Solid State 4 14th February 2007 11:30 AM
Copyright 1999-2017 diyAudio
