Hi
I just bought the Hypex ucd180hg and the smps1200a180 power supply.
I was wondering if someone could confirm the connections between the power supply and the amp module as I’m abit confused when looking at the boot strap VDR connections.
Do I join J1.1 and J1.2 (vdr+ and HV+) on the smps and take them to the positive input on the amp modules and J1.4 and J1.5 (vdr- and hv-) to the negative rail?
Or do I just join HV+ and HV- to the positive and negative rails? If so what do I do with the bootstrap VDR connections?
Sorry for stupid question I haven’t been able to find a connection diagram. I’ve found one for the ucd180hg with smps400 but not the smps1200a180
Any advice or guidance would be greatly appreciated
Thanks heaps
Smps1200a180
https://www.diyclassd.com/img/upload/doc/smps/smps1200/Documentation/SMPS1200Axx0_07xx.pdf
Ucd180hg
https://www.diyclassd.com/img/upload/doc/ucd/ucd180hg/Documentation/UcD180HG_R4.pdf
Connection diagram I found but this is for the smps400
https://www.diyclassd.com/img/upload/doc/ucd/ucd180hg/Documentation/UcD180 + SMPS400.pdf
Thanks heaps
Smps1200a180
Ucd180hg
If I were building it I'd leave the bootstrap pins disconnected. But I'd confirm that with someone else first.
Hi Fox
Thanks for your feedback. I finally got a reply to my email from Hypex.
It appears your correct the bootstrap stays disconnected with the smps1200
The ucd180hg needs only the HV voltage from the SMPS. So I would connect:
UCD J3 to SMPS J1.2 positive voltage
UCD J2 to SMPS J1.5 negative voltage
UCD J1 to SMPS J1.3 ground
Optional you can connect UCD J4.1 with SMPS J4.6. With connected the SMPS
delays the startup of the ucd. But the ucd has an own startup delay, so it's not
mandatory.
mandatory.
mandatory.
Thanks arnd appreciate your feedback
Related question
I found your thread when looking for clues. I just sent an email to Hypex asking for support. I just finished my stereo 3-way syste, with active crossover using Hypex DLCP in once enclosre and 6x Hypex UcDHG+HxR in a second enclosure, connected with 6 XLR interconnects.
I'm getting no sound.
Only red leds light up on the UcD's. No blue leds.
I did not connect J4.1 (UcD) to J4.6 (SMPS1200). I thought this may be the cause, but your post above from april seems to reject this as the cause, sating that the On/OFF enable signal is not mandatory.
I also did not connect J4.1, J4.2 (Vaux / Vaux/REG) , J4.3 (ground), J4.10 (DC error) on the SMPS1200. Should I? Where to and how?
I also did not connect J5 on the SMPS1200. SHould I? Where to?
I also found this part of the whole project the most unclear.
I hope Hypex wont take too long in responding. I'm impatiant, having finished the project finally!
- Class D
- Hypex ucd module connection question?
