Total noob - want to build (assemble) 6-channel amp
Old 15th May 2018, 01:36 AM   #21
solid7 is offline solid7  United States
So what would I want to use to "turn down" the amp power? I have way too much available power for the application that I'm starting with. (although it will be excellent for future projects)
Is there a good way to limit power output, without degrading performance?
I don't want someone to damage my speakers, if they aren't familiar with the equipment. I need to put it in "valet" mode, so to speak...
Old 15th May 2018, 02:35 AM   #22
thizzgiant is offline thizzgiant  United States
I don't have experience with your particular amplifiers but with the minidsp you can control the gains on both inputs and outputs, lowering those into a sweet spot should keep your speakers from being over driven. It's what works for me. Good luck!
Old 15th May 2018, 06:27 AM   #23
Nenola is offline Nenola  Finland
That might be it. The board has 3-pin connector for a mono potentiometer to do the job. The pot could be installed behind the amplifier or some other secure location.
Old 15th May 2018, 01:53 PM   #24
Would that affect sound in any way? Introduce any kind of unwanted noise or interference?
Old 16th May 2018, 05:07 PM   #25
Originally Posted by MAAC0 View Post
I've seen many amps using that grey CD-ROM analog type cable for signal.
From the amp module to the speaker terminals? Or just from the inputs to the module?
Old 17th May 2018, 02:02 PM   #26
If he means IDE/ATA cable, I would use it only for input wires. For outputs something thicker.
Don't have the answer yet, my project is unfinished because of broken solder iron
But I think the potentiometer isn't directly connected to any of the inputs or outputs, so it probably is noise-free.
Total noob - want to build (assemble) 6-channel ampHide this!Advertise here!
First post, total noob. I need serious help. coalnation Introductions 1 12th April 2014 04:15 PM
total noob+dying amp questions ozawa Solid State 5 2nd September 2013 04:58 PM
Total NOOB question about WinISD petervr Full Range 7 23rd June 2013 03:54 AM
Total noob with blown Pre-amp Colday Analogue Source 96 5th December 2011 05:36 AM
Total Noob- need some advice/ direction BigguyZ Solid State 10 6th August 2010 08:30 PM
