Trying to figure out a solution to a small circuit
Old 17th March 2018, 09:24 AM   #1
Wuchan is offline Wuchan
Default Trying to figure out a solution to a small circuit
I am extremely new to electronics, I have been trying to figure out a solution to a small circuit I am trying to mod for the Gameboy color. The GBC has a very low speaker output. Using the PAM8302 (a class-d sound amp datasheet: http://www.kynix.com/uploadfiles/pdf...M8302AADCR.pdf), I connect the RIN (U3 pin 7) to IN- of the PAM8302 and PAM8302 OUT+/- to the speaker. The sounds works great, but when I want to plug in my headphones it plays through both the speaker and the headphone jack.
In the original circuit the headphone output is disabled by the headphone jack via Pin 6 of U3 being pulled down by pin 4 of the phone jack. When the phone jack is inserted, the pin is no longer pulled to ground thus disabling the speaker. I need to apply a modded circuit to act the same way to the new amp I am installing. I would like the switch in the phone jack to disable the speaker amp I installed. I wanted to use a transistor to toggle the PAM8302 enable pin (5v enabled; 0v disabled), so when the headphone jack is in the PAM8302 is disabled and vice versa. Also, FYI the output of U3 pin 6 is 0.7v
I thought a transistor might do the job, but I am not sure if I am being realistic.
I really hope I have been clear here; any suggestions are appreciated greatly.
Old 17th March 2018, 10:06 AM   #2
JonSnell Electronic is offline JonSnell Electronic  United Kingdom
JonSnell Electronic's Avatar
Your schematic doesn't use the PAM chip that has 8 pins. It is something different. Without knowledge of part number, could be anything.
Support for Fender, Marshall and all Valve Equipment; Audio Innovations, Audiorama FU29, Quad and Leak. www.jonsnell.co.uk
Trying to figure out a solution to a small circuitHide this!Advertise here!
help with voltage figure for mic pre-amp circuit Pauld35 Instruments and Amps 8 7th August 2016 07:30 AM
Small rooms under 150Hz, is there any solution. silverprout Subwoofers 25 6th May 2016 04:59 PM
Bass solution for a small room paulfk Multi-Way 0 24th November 2015 11:27 AM
