Class D amp + EMI reduction
Old 17th March 2018, 11:28 AM   #31
maty tinman is offline maty tinman  Spain
maty tinman's Avatar
Many years ago a friend told me a phrase that I always remember when I have no explanation: electronics is very mysterious
Old 17th March 2018, 11:35 AM   #32
djpns is offline djpns
Hahaha you're so right my friend! That's why I love Electronics
Old 17th March 2018, 12:31 PM   #33
OffGridKindaGuy is offline OffGridKindaGuy  United States
OffGridKindaGuy's Avatar
Yup.. Them thar RF's are strange critters..
Old 17th March 2018, 12:51 PM   #34
My problem/confusion was that I was thinking about the problems I had with my class AB amplifier and I did not realize that Class D works internally with a higher bandwidth.
Old 17th March 2018, 01:00 PM   #35
I've used an RC low pass tank circuit with good results. Cut a foil and insert a 60 ohm resistor, bridging the cut, close to the solder pad. Add a 20pF cap after the resistor to ground. (Using surface mount components)
I've done this right at the wire connections on the board. Cut the signal trace right at the solder pad and bridge with the resistor. Install the cap across the wire solder pads, shorting them out with the cap. This provides a low pass circuit that will filter everything above ~130 MHz
I discovered this on a 2.1 amp and the trash from the chip was getting into the sub level control. I installed this filter on the board at the solder pads for the control and the problem went away.
This could be used on the power input also with low current draw demands. 60 ohms isn't going to drop much voltage. Many times that is where the crap is getting into the receiver..
Last edited by OffGridKindaGuy; 17th March 2018 at 01:10 PM. Reason: 'cause I could..
Old 17th March 2018, 04:45 PM   #36
Do you have a schematic of all these connections? It would really help me.
Old 17th March 2018, 07:34 PM   #37
No schematic. All boards are different. The mods I refer to are on/near the outside connections to the board. (plugs/sockets, solder points for external wiring, ect..)
Follow the board traces to the external connections on the board. Cut the trace and jump the cut with a surface mount resistor as close to the edge as possible. Most cases are at the point of which the trace ends at the solder pad for an external connection. The +/- pads are usually close enough to solder a cap across them. Short the pads with a cap..
Soldering a resistor to the cut trace might be difficult for someone who doesn't have lots of experience in soldering. The trace needs scraped to get rid of the insulation so the solder can stick and not destroy the trace. Also, not to scrape any near by traces to avoid bridges. Not a task for a novice..
Old 17th March 2018, 07:40 PM   #38
Yeap, it sounds like a task for experienced persons. And I'm not. Is there any filter board on the market that I can use?
Class D amp + EMI reductionHide this!Advertise here!
physical hum reduction in class A amps aspringv Pass Labs 2 1st February 2018 10:35 AM
Hum reduction dotneck335 Instruments and Amps 2 30th January 2018 04:40 PM
TIM reduction for tweeters ArthurDK Multi-Way 62 14th March 2016 04:23 AM
Feedback reduction mic weiyan PA Systems 10 14th May 2013 12:47 PM
