running with no load
Old 13th March 2018, 07:05 PM   #21
DreadPirate is offline DreadPirate  United States
DreadPirate's Avatar
I don't believe I had anything connected up to the amp, it was just powered with no connected load. The C34 chip was not damaged at all.
I would give it all up for just a little bit more...
Old 14th March 2018, 02:25 AM   #22
forestsgump is offline forestsgump
[QUOTE=voltwide;5370798]To clarify this problem: The output LC-tank has a resonant frequency in the range of 50 kHz. If you connect a 50kHz-signal with the input, the output of the amp sees a very low impedance of the series resonant tank. In that case
1) The voltage at the resonant cap (680nF) may rise far above supply voltage thus destructing the cap.
2) Output current exceeds limits and over-current protection trips.
But...
If you do not connect 50kHz to the input, the resonant tank is not excited../QUOTE]
What mean, if i have the op-amp input shorted, its output to TPA wld be muted, thereby no way to excite resonant frequency. Then in this case no danger at all even without load?
Old 14th March 2018, 03:18 AM   #23
voltwide is offline voltwide  Ireland
Yes
Old 15th March 2018, 04:00 PM   #24
Originally Posted by Khron View Post
I'm a bit surprised of 1N400x's being recommended. If anything, i'd rather expect some fast-recovery diodes in those positions (since you have the several-hundred-kHz switching waveform going on, before the output filter). Something like UF400x's or MUR1x0's or something.
Quick question: on these clamp/catch fast-recovery diodes
Any reference specs suitable?
~ Peak Reverse Voltage, Maximum Current, How fast-switching?
I found some high efficiency recifier HER501~508, not sure suitable to do the job?
Old 15th March 2018, 04:29 PM   #25
Khron is offline Khron  Finland
Send a message via AIM to Khron Send a message via MSN to Khron Send a message via Yahoo to Khron
Reverse voltage, 50-100% greater than the supply voltage; current, 1-2A should suffice, i'd reckon; switching speed, anything rated for fast switching.
Those HER50x's might be a bit overkill, actually
Khron's Cave - Electronics - Audio - Teardowns - Mods - Repairs - Projects - Music - Rants - Shenanigans
Old 15th March 2018, 06:07 PM   #26
I guess the 100V type should be fine.
Old 15th March 2018, 06:12 PM   #27
DPH is offline DPH  United States
RF ingress is a real possibility depending on what sort of input filtration you have. Shorted inputs to ground *should* obviate this concern, though. (Unless things go really badly)
Happy DIYing, Daniel
Old 15th March 2018, 11:35 PM   #28
Thanks these are cheap - even found some HER208 (2A1000V) are 1/3 cost of HER50x's
running with no loadHide this!Advertise here!
Running valve-rectified power supplies without load chaerin Instruments and Amps 7 19th August 2017 11:52 AM
LM4780 inductive load running hot zdr Chip Amps 12 6th February 2017 08:58 AM
Running an amp on an unrated load wbuentello Class D 7 29th May 2015 10:28 AM
DDDumy Load, a versatile power dummy load tool dddac Equipment & Tools 6 14th January 2014 12:36 AM
What advantages running ported midbass if you are running a sub? mitchyz250f Multi-Way 3 20th May 2008 02:34 PM
