TDA7492p low volume
TDA7492p low volume
Old 22nd February 2018, 09:24 AM   #1
Andreasdeleuran is offline Andreasdeleuran
Default TDA7492p low volume
Hi guys.
Please be warned - i'm new
I have a simple question. I bought a TDA7492p - no buttons and no aux.
It works perfectly fine in a small PA speaker. It does however play on different volume levels depending on the connected device.
My tests
On the following phones it plays perfectly loud:
- Iphone 8 and oneplus one
And the ones where the volume is waaaaay lower:
- Huawei mate 10 lite and Samsung s6 edge
Any explaination/solution.
Every answer is greatly appreciated!
Old 22nd February 2018, 11:00 AM   #2
FauxFrench is offline FauxFrench  France
Hi Andreas,
I assume you use the headphone output from the phones?
The most likely reason for the difference in sound-level is that the signal outputs from the phones are different in level.
Take one loud phone and one low phone and test that they have a significant difference in sound level when used with your TDA7492.
Let your phones continue playing music and don' t touch the volume buttons on the phones.
Then, without switching your phones off or stopping the music, try if there is a corresponding difference when you use a headphone (the same) directly on the two phones.
If they play equally loud in the same headphones, it may be a difference in output impedance that causes the sound level differences.
Old 22nd February 2018, 11:08 AM   #3
Thanks for the answer. As i said - there's no AUX input on the amp and it's purely used via Bluetooth.
Old 22nd February 2018, 09:38 PM   #4
Andreas, your presentation of the problem: "...a TDA7492p - no buttons and no aux." did not mention Bluetooth. "TDA7492P" is an amplifier chip not including any Bluetooth.
Now I believe to understand your problem better. My trivial conclusion is that it is not an amplifier problem because with some phones the amplifier just works very well.
The problem is in the Bluetooth streaming between your phone and the Bluetooth chip.
This is an amplifier (class D) thread and there may be other threads that are more relevant for such a problem. But, you can also take your chances here if you prefer.
A trivial question: For the two phones that play way too low, is it so that you cannot increase the level with the phone volume buttons?
TDA7492p low volumeHide this!Advertise here!
TDA7492P 3.5mm issue novice121 Class D 0 3rd September 2017 11:00 PM
Which version of TDA7492P should I use? Zerlen Class D 3 6th July 2017 04:56 PM
Powering TDA7492P luisxd Class D 3 16th April 2016 01:33 AM
Add aux input to TDA7492P luisxd Class D 5 15th April 2016 09:35 PM
TDA7492P 50W/50W Ebay - AUX Input Volume Lower Than Bluetooth Volume? iammrhappy123 Chip Amps 4 9th November 2015 10:40 PM
