hypex Ucd wiring - Please Help
Old 8th February 2018, 02:29 PM   #11
Brendanaudio1 is offline Brendanaudio1
The pics showed up on my desktop, obviously cos they are located there. Lets try the proper way now. Thanks for letting me know2017-12-11-PHOTO-00000182.jpg
Old 8th February 2018, 02:30 PM   #12
Hope it works this time. Thanks again Mooly
Old 8th February 2018, 02:31 PM   #13
Mooly's Avatar
there you go.
Old 8th February 2018, 02:41 PM   #14
Koifarm is offline Koifarm  Netherlands
Koifarm's Avatar
if vdr voltage is not used, pin must be connected to gnd. See manual.
https://www.hypex.nl/documenten/download/838
Old 8th February 2018, 02:52 PM   #15
Would this prevent the amp from turning on?
Old 8th February 2018, 03:08 PM   #16
Koifarm's Avatar
pin 21 and 27 needs to be low(gnd) to power on.
How did you connect asymmetrycal signal?
Old 8th February 2018, 03:13 PM   #17
Pos and negative normal, and gnd to earth
Old 8th February 2018, 03:18 PM   #18
Koifarm's Avatar
For asymmetrycal(unbalanced) you need signal to hot and shield to gnd and cold to gnd.
Old 8th February 2018, 03:50 PM   #19
Koifarm's Avatar
Originally Posted by Brendanaudio1 View Post
My power supply to OEM connector board is 100%. voltages measure 100%. Speaker outputs also no probs. My suspicion is the input connectors, if someone can shed some light. I have connected ground to the mains earth, which is not connected on the PSU, if that makes any sense. Did this for unbalaced connection. I'm happy to do whatever, just to get it operational.
Do not connect mains earth. As stated in manual.
https://www.hypex.nl/documenten/download/1291
Old 8th February 2018, 04:12 PM   #20
Grounded them. ITS AALLIIVVEE. Working perfect. Thanks you so much. My leaflet that came with the amp failed to mention that. Thanks again
hypex Ucd wiring - Please HelpHide this!Advertise here!
Wiring for Hypex SMPS 1200 and 2X Nc400 alexIG Class D 8 26th August 2017 12:21 AM
Hypex UcD400OEM wiring problem dave123 Class D 6 30th December 2015 01:06 PM
Hypex UcD400HG + HxR & Hypex SMPS400A400 Wiring Questions Nirvana5253 Class D 3 12th March 2015 05:26 PM
question regarding hypex ucd wiring Putzeudel Class D 4 26th October 2012 08:40 AM
Wiring up the Hypex power supply SMPS 180? cirrus18 Class D 9 14th November 2008 08:03 PM
