Lepai 2020 - moved potentiometers off board with wires, getting interference
Old 14th January 2018, 12:32 AM   #1
BMOC is offline BMOC
Default Lepai 2020 - moved potentiometers off board with wires, getting interference
Hi Guys,
I apologise if this has been covered, I did search a lot but couldn't find much to address this issue.
I have a Lepai 2020 that I'm putting into a custom built unit. I have the amp mounted inside and I've taken the three pots off the board and mounted them in a control panel on the unit (see attached image). Everything works, but I get serious interference unless I push the tone button to bypass the bass/trebel pots. If I hold the new control panel in my hand, I get no interference (presumably because this grounds everything).
I'm not overly knowledgeable when it comes to electronics. I thought that maybe because the volume knob appears to be grounded (extra wire from outside of pot to board) that maybe if I did the same with the other pots that might eliminate it? But when I connected some wires between those pots and the same ground point for the volume point it did nothing.
Any suggestions? Should I have used shielded wires? Can I add shielding to the bundles of wires? Is there another way I can ground this without added a bit chunk of metal to the stereo?
Lepai 2020 - moved potentiometers off board with wires, getting interferenceHide this!Advertise here!
Lepai LP-2020 jankanda Chip Amps 14 26th January 2016 11:18 PM
Lepai 2020 - no sound at all! Crypto Class D 7 11th June 2014 12:18 PM
Lepai 2020 as measurement amp? tuxedocivic Equipment & Tools 4 19th March 2012 08:14 PM
SureTA-2024 Board integrated in Lepai LP-2020 - Quad Channel amp QT0815 Class D 3 13th February 2012 10:11 PM
Lepai LP-2020 mod to include sub out rziebro Class D 1 12th February 2011 03:01 PM
