T1-M power supply 12v vs 24v
Old 7th December 2017, 08:59 PM   #1
philj is offline philj  United Kingdom
Default T1-M power supply 12v vs 24v
I have a T1-M left over from another project. I'd like to use it in another low budget project, but I'm stuck on power supply.
Ideally I'd like to use what I have as the recommended power supply is 40, but at the moment that is only 19v at 3.6a, or 12v at 10a and 16a. The 16a is an old xbox 360 power supply.
This is the specifications for the amp.
Ouput power (stereo) RMS @6 ohm with supply voltages: 24V - 42W, 21V - 33W, 18V - 23W, 15V - 16W, 12V - 10W, 9V - 5.9W
I'll be running 6ohm 89db speakers.
Does this basically mean it won't be very loud?
Seems a step up converter is an option, but am I right this is at a cost of 20% efficiency? The main point of the smaller amp in this situation is the lower power consumption, so I'm looking for an efficient option.
Old 7th December 2017, 11:26 PM   #2
Could this work?
AC-DC Switching Power Supply Module AC 100-240V to 24V 9A Power Supply Boar I4H6 | eBay
T1-M power supply 12v vs 24vHide this!Advertise here!
If a DAC asks for a 7v - 9V power supply, should I used a 9v 2000 mA power supply, or ag8908 Digital Line Level 2 26th March 2014 06:24 PM
Making Symmetric Power Supply from Single with 4x ATX power Supply? lupetalo Power Supplies 11 20th November 2012 11:51 AM
Power supply positive-negative-ground from a single power supply mome Power Supplies 8 9th September 2011 05:17 PM
heater supply (xformer specs are 6.3V 2.5A) as supply for a power LED? jarthel Tubes / Valves 10 21st July 2003 01:30 PM
