TPA3250 somebody is listening ?
Old 4th December 2017, 09:55 PM   #31
Kjeldsen is offline Kjeldsen  Denmark
If you have heard well constructed class D amps, then these cheap class D boards are just toys. The ancient Tact Millenium is still way, way better, than any TI class D board.
http://kjeldsensforbindelser.dk
Old 4th December 2017, 11:17 PM   #32
FauxFrench is offline FauxFrench  France
Some of you guys/girls own amplifiers so expensive that I have not even heard about them. No doubt also what you call "well constructed class D amps".
But, for each "well constructed class D amp" sold the toy "cheap class D boards" sell by ten thousands.
The "cheap class D boards" will steadily approach the "well constructed class D amps" in performance, but the "well constructed class D amps" will not increase their sales towards the numbers of the "cheap class D boards".
In conclusion, the monolithic (cheap) class D amplifiers are interesting because they satisfy the needs of the absolute majority of users (ordinary people) and indicate the developments in the market.
The very high performance class D amplifiers are important because they demonstrate what is possible with this technology, but they will never be mainstream in any way.
It seems that ICEPower was (is?) an important source of that sophisticated technology.
So, for us ordinary people the toy amplifiers are interesting because they reflect the trend and give us pleasure from convincing performance though not the ultimate.
Said in other words: it is not because there is a Bentley on the market that there is no need to consider the new Opel Insignia.
Yep, (some) class D amplifiers absolutely qualify to audiophile standards.
Old 4th December 2017, 11:59 PM   #33
ICG is online now ICG  Germany
ICG's Avatar
Location: Too many amps, too many speakers, too little time
Ah, that's apples and pears. The TacT Millennium is for a very good part that good because it does not amplify analogue signals, it's directly driven by the internal DAC, and it does not re-sample the signal for different volumes. It cannot reproduce any analogue signals and not even all digital sources. If you'd add the analogue part (or get rid of it on other class D amps), the distance between them would melt like ice in the sun. Possibly still with the tact ahead but that's to be expected, considering the price tag of meager 12000€. No, that's not a zero too much.
I had a Déjà Moo - I've seen that BS before!
Old 5th December 2017, 07:57 AM   #34
Not true IMHO. The digital frontend of the Tact Millenium is not the strongest issue. Yes, you don't need an expensive DAC. But, a very good class D amp with a very good DAC is comparable to Tact Millenium.
Not all Tact and Lyngdorf amps are pure digital.
I have tried them all :-) all types of class D in all price ranges (well not all - but more than most). Class A - cheap and expensive. Class AB cheap and expensive. Tubes only cheap and mid priced.
All topologies can make very very good reproduction. My point is - please do not judge class D based on cheap TI boards from China.
Old 5th December 2017, 08:02 AM   #35
Originally Posted by dellama View Post
The two that come immediately to mind are their propensity for poor linearity above 6khz and their poor noise floor but there are others.
This is not true. Where do you see that the class d topology is not linear above 6 khz (are you talking frequency or distortion ?), and where do you see the poor noise floor (not specific amplifiers but the topology)
Old 5th December 2017, 12:16 PM   #36
ICG's Avatar
Well, that's exactly what it is at the Tact Millenium, the eliminatin of the analogue source, all it's distortions, influence and tolerances and unlinearities of a lot of components in the input. Add the analogue part and the huge difference shrinks together like nothing. Ofcourse it's still much better but not by worlds anymore. That's not just my opinion, a lot of tests say exactly the same.
That I can fully sign.
Old 5th December 2017, 09:42 PM   #37
dellama is offline dellama  United States
Kjeldsen
I was talking about distortion mainly but it's both. Check out this link. The stubborn noise floor is due to the constant switching in the active devices which is mostly a problem with this type of design.
Old 6th December 2017, 11:04 AM   #38
I don't see how this article contributes. I can show you Class D measurements that are very very low distortion at all frequencies and very linear up to +100 khz.
I'm not a class d fanatic - actually I'm planning to have all types of amplifiers in my system, to be able to change technology from time to time.
Old 13th December 2017, 06:50 AM   #39
forestsgump is offline forestsgump
Originally Posted by frazier View Post
FX-Audio has introduced an amp based on the TPA 3250 chip. Under $70 got to be kidding right? Following the diy efforts on the TPA 32xx chips I think our Chinese friends presented this particular amp with the note,[ preamp uses OP amp NE 5532 : Replaceable design suitable for DIY,] for our benefit .- Maybe-. Has anyone checked this out? thanks
Any suggestions what would be a good OP amp to replace NE 5532 for this TPA3250?
2 choices:
1# Just for great audio quality
2# If cost is not an issue.
Old 13th December 2017, 02:47 PM   #40
ICG's Avatar
Kjeldsen
That article is a prototype on how not to write objective articles.
Firstly, they measure some frequency response but don't tell you what it is except the brand of the amplifier (just Axiom Audio Class D). And they don't even tell this in the article itself either, you have to grab that information out of the measurement diagrams.
Secondly, the output filter is clearly heavily mismatched with the load impedance. That is, if they connected one at all, but they don't write anything about that either. Ofcourse that displays a problem of class D amplifiers, but it's that bad, it's pretty obvious the load impedance is much too high for the filter and it pretty much looks like it was intentionally done that way to make class D look bad.
Thirdly, the 2nd measurement is a different amplifier. To make the impression how inferior the amplifier impedance/damping factor is, they use sentences like 'We can hope (without success)..' to describe non-resistive loads - instead of just measuring it themselves. They did not do any distortion or noise measurements.
In any way, these measurements are crude, they didn't tell about any measurement circumstances and -equipment, which is standard. But that got an obvious reason, they seem to have inferior measurement tools, at least the very low sample resolution and frequency steps of the impedance measurement suggest that - there are just 4 different, always exact same values from 10Hz up to 5kHz.
To put the resulting damping factor into perspective, the measurements of the amplifier impedance at 8 Ohm load translate to a DF of 53 at 20kHz, 66 at 15kHz and 100-114 for everything below 9kHz. That's pretty much standard specs also for average class A/B amplifiers, even good for multi-channel amps. Sure, that's not impressive for a supposedly high end amplifier (if there's such a thing in home cinema) But again, like someone already said, it's not 2007 anymore and there were a lot of developments on the class D amplifiers in the last 10 years. And there are also a lot of other very expensive amplifiers which don't have any better specs there either.
To dig up such old and very obviously 'tinted' articles as unalterable facts to prove 'class D is baaad' suggests it might either be ignorance, willful mischief or trolling but I honestly believe it's neither of these and there might be hope for an open ear for some arguments, measurements and facts.
Things change. A previously widely accepted assumption/opinion can lack it's very foundations because of technological advancements over time. And 10 years is a very long time in electronics.
TPA3250 somebody is listening ?Hide this!Advertise here!
MPA 3250 Amp johnmik Solid State 16 10th March 2017 07:50 PM
RD Audio 3250.1 Deadly Sones Car Audio 1 10th July 2013 06:51 PM
RD Audio 3250 V2 S Merlington Car Audio 3 28th February 2013 06:55 PM
What are you listening to? MikeW Pass Labs 36 20th June 2011 02:54 AM
Denon DOA-3250 mike49504 Car Audio 2 12th November 2010 09:17 PM
