TI TPA3255EVM
TI TPA3255EVM
Old 18th February 2018, 12:40 PM   #551
watchtmouse is offline watchtmouse  Germany
watchtmouse's Avatar
Default new TPA3255EVM user
Hi All,
Ordered the TPA3255EVM board together with a Mean Well USP-350-48 (350W Single Output with PFC Function, no fan).
This Mean Well USP-350-48 has no screw down terminals, ( I did not notice ) so I need to order:
2 x Buchsenleiste (Standard) VH Polzahl Gesamt 7 JST VHR-7N Rastermass: 3.96 mm 1 St. kaufen
1 x Buchsenleiste (Standard) VH Polzahl Gesamt 5 JST VHR-5N Rastermass: 3.96 mm 1 St. kaufen
3 x Buchsenkontakt VH Polzahl Gesamt 1 JST BVH-41T-P1.1 1 St. kaufen
Put together today and was surprised that I had no sound from the right channel, no wonder because Page 3 of the User documentation for the TPA3255EVM states:
"The input RCA jack, J3, is used to provide INA inputs and RCA jack J14 is used to provide INB inputs. RCA jack J18 is used to provide INC inputs and RCA jack J15 is used to provide IND inputs with differential inputs.".
Luckily the 2.1 schema on page 5 shows the right configuration, to get the right channel working from my iPhone so I used J3 and J18 for single ended inputs.
Mentioned before, but repeating here boards dimensions are 160 x 120 mm and not 140 x 120 mm as stated on page 12.
The actual height of the evaluation kit is 78 mm, (Measured bottom of the standoffs on the table up to the top of the heatsink).
For the first listening form the pod I have no complaints.
See picture of the setup.
Happy listening
Grtz
Bert
Old 18th February 2018, 04:50 PM   #552
Default Too much and a good match
One more time today,
This amp "TPA3255EVM" is too much for my old test speaker the small JBL Northridge E 20.
But a perfect match for my KEF LS50 speakers, with the "I pod" playing I can not tell about the full spectrum, but the "I pod", TPA3255EVM and the LS50 are a very nice trio for long listening sessions.
Hopefully, next week I will connect the DDDAC-1794, and check that combo.
Until then happy listening too all.
Grtz
Bert
Old 18th February 2018, 04:53 PM   #553
rhing is offline rhing  United States
rhing's Avatar
I use the TI TPA3255EVM with a pair KEF LS50 speakers as well, and they are a great match. Give the amp some time to really burn in and connect a better source—you will really be pleased with the results.
Rich
Old 22nd February 2018, 08:27 AM   #554
a3cervo is offline a3cervo  Philippines
Hi watchmouse,
Do you experience turn-on or turn-off thump/pop with your TPA3255EVM+MW USP-350-48?
Thanks,
Anton
Old 22nd February 2018, 11:28 AM   #555
Yes, I do have turn-on/off thumbs.
I use the reset button on the EVM to "prevent" the turn-on turn-of thumbs
I set the button to reset mode before power-on, when I hear the click on the mean well PSU and the green led on the EVM board are on, I set the reset switch to the normal position. On power-off I do the reverse.
Grtz
Bert
Old 22nd February 2018, 11:41 AM   #556
SanjeevM is offline SanjeevM
If you dont use the reset button, are the thumps very loud, like speaker busting loud, or just loud clicks?
RPi 3/ Boss DAC 1.2/ TPA3251/ IFI Power 5V & Allo Adapter/ Paradigm Monitor 11 / Non-Electronics background
Old 22nd February 2018, 11:42 AM   #557
I have a 3eaudio tpa3251 board, where its just a mild click.
Old 22nd February 2018, 11:59 AM   #558
Default Just thumbs, not speaker "killing"
The thumbs are very audible, but not speaker "killing"
Grtz
Bert
Old 22nd February 2018, 12:12 PM   #559
DizRotus is offline DizRotus  United States
With my efficient DIY horn-loaded speakers the turn on “thump” is more of a click.
I struggled with what to do about the reset button after putting the EVM and Meanwell in a case. Rather than relocating the reset to the exterior, I leave it at “normal” and control line voltage to the Meanwell from the on/off switch on the case.
I use one of two Pono players in lieu of a pre-amp. I always turn on the Pono player first before powering the Meanwell, and the reverse at shut down. The noise heard from the speakers is negligible.
FWIW, at idle between tracks on songs, there is NO hum from the very efficient speakers. With any tube amp I ever used, there was always a slight hum under those conditions.
Neil
Old 22nd February 2018, 12:48 PM   #560
Thanks Bert, planning to put this in a DIY case and I want to know if I need to make a hole in the enclosure panel where the reset button is so I can toggle the switch during turn on.
Grtz
Bert
Hi DizRotus, how did you control the line voltage to the Meanwell psu. Sorry I'm very green on this topic and honestly this is gonna be my first amplifier project
If you can post a picture of the internal of your amp, I would really appreciate it.
Thanks and regards,
Anton
TI TPA3255EVMHide this!Advertise here!
TPA3255EVM to complete amp (advise needed) VerticalEaz Class D 67 15th January 2018 03:05 AM
tpa3255evm spacesaver mod robinlawrie Class D 84 12th December 2017 07:20 AM
