Stepping up from the TPA3116 - amplifier recommendations to fit my new chassis?
Old 4th October 2017, 02:28 AM   #1
JonesySA is offline JonesySA  Australia
Default Stepping up from the TPA3116 - amplifier recommendations to fit my new chassis?
Hi all
It has been a while since I modded/built an amplifier so I'm out of the loop. Could I have some recommendations please?
I have the following chassis:
Single large VU amplifier chassis
New Aluminum VU meter amplifier Enclosure chassis case/amp box for DIY YA53 | eBay
Internal dimensions:
Width = 210mm
Height = 83 mm
Depth = 295mm
I wish to keep everything within the chassis (however would entertain using a large external laptop brick etc) and the sound quality should be as good as TPA3116 however more powerful. I'm not looking to spend silly amounts and am a fan of the class D amps and cheap boards.
My speakers are usually 6-8 ohms.
What chip/board would you suggest?
Also; the chassis has two rotary dials on the front and would like at least remote on/off volume and input selection. I have seen these on ebay but no reviews:
9V Infrared Remote Control Volume Control Board ALPS Pre AMP Motor Potentiometer
9V Infrared Remote Control Volume Control Board ALPS Pre AMP Motor Potentiometer | eBay
4 Way Input Source Selector For Audio Preamp Amplifier DIY Kit / 4 In 1 Out
4 Way Input Source Selector For Audio Preamp Amplifier DIY Kit / 4 In 1 Out | eBay
or an all in one version:
Remote ALPS motor Volume control preamplifier board + Standby board R112
Remote ALPS motor Volume control preamplifier board + Standby board R112 | eBay
Old 4th October 2017, 10:03 AM   #2
Jerms is offline Jerms  United Kingdom
TDA7498 or TAS5630 spring to mind.
This page might help if you cross search with DIYAUDIO.
Analog Input Class-D Amplifier l Products l Audio l TI.com
TPA3255 has been mentioned recently.
J.
Stepping up from the TPA3116 - amplifier recommendations to fit my new chassis?Hide this!Advertise here!
My first Amplifier Build (TPA3116) Count Sudoku Class D 6 10th September 2017 05:03 AM
TPA3116 eBay/China Speaker Protection Board recommendations ebivan Class D 11 7th October 2016 01:34 AM
Recommendations for a finished TPA3116/TPA3118 unit nanon Class D 17 4th December 2015 06:03 AM
TPA3116 in Hammond Chassis cervelorider Swap Meet 0 10th January 2014 02:14 AM
ebay TPA3116 2.1 amplifier tigox Class D 21 17th December 2013 04:54 PM
