TPA3118 noise and pop sound
Old 4th October 2017, 10:13 AM   #11
papaarrugada is offline papaarrugada  Germany
Hi again,
I want to report my results after studiing the data sheet.
I decided realizing a gain of 20dB and changed the resistors.
Noise is very low, but my max. input level was not enough.
Therefore I changed to 26dB, noise is about half in comparison to beginning and my input level was enough.
From both resistors 39k and 100k I left the 100k and placed a further 39k in parallel to the original. This makes 19.5k, best value in data sheet is 20k with 5% tolerance.
I tuned all my 8 amp boards.
Next step is muting from raspberryPi over GPIO pins and a delayed switched relay in the power supply of the amp boards.
Thank you all for the help and informations!
Old 5th October 2017, 09:53 AM   #12
selwe is offline selwe
Originally Posted by papaarrugada View Post
Hi again,
@papaarrugada Can you please add some illustrations/pictures/schematics with the mods you made?
Old 8th October 2017, 12:57 PM   #13
yes, of course.
gain can be selected with two R's.
The table of datasheet shows following selectable values in master mode:
gain | R1 to GND | R2 to GVDD
20dB | 5,6k | OPEN
26dB | 20k | 100k --> I have selected
32dB | 39k | 100k --> default setting
36dB | 47k | 75k
therefore I had to change R1 from 39k to 20k.
I decided to place a second 39k on the top of the default R 39k.
Two 39k R's results in 19,5k, 20k is the suggested value in the table.
But it's in the 5% tolerance (19k to 21k).
I want to add a picture where you can see the "construction".
But I don't know how I can import a pic.
TPA3118 noise and pop soundHide this!Advertise here!
TPA3118 SANWU noise problems meira007 Class D 25 11th March 2017 02:35 PM
about the Sound/Noise that go through the Cone... JonBocani Multi-Way 59 10th January 2017 08:08 PM
Sound Masking System - White noise -_nando-_ Everything Else 8 6th April 2016 11:37 PM
PC noise through internal sound card Kev06 PC Based 54 2nd March 2015 10:26 AM
What does pink noise sound like? jamikl Multi-Way 23 31st July 2008 02:23 AM
