TPA3116 + CSR8635 Idle Noise
Old 7th October 2017, 09:15 PM   #31
baklazanowy is offline baklazanowy
Oooh Okey. Thx!
Old 8th October 2017, 11:11 AM   #32
doctormord is offline doctormord  Germany
doctormord's Avatar
Your need to remove 4 resistors and 4 capacitors. Then solder 4 wires to the pads marked by the dots. Keep the wires together in pairs. R+/- and L+/-
Old 10th October 2017, 02:00 PM   #33
Hi ! Mod successful ! The idle noise is much less audible !
doctormord you made my day ! Thank you !
Old 10th October 2017, 02:11 PM   #34
doctormord's Avatar
Does the noise figure changed? Before i'd guess it was some kind of modulated digital noise, now it should be more like static noise. If there are still artifacts of digital noise left, we will need to alter the power supply for the BT module.
Old 10th October 2017, 02:20 PM   #35
In both cases it was a static noise. Without mod the noise is way to high ! When music stops, only the noise comes from the speakers. For exemple when I turned on this device, and device is waiting for BT connection - only noise is present.
After the mod noise is still present - static, but value of this noise is much less - let's say on acceptable level for me. Of course in perfect scenario the noise could be gone
Old 10th October 2017, 02:22 PM   #36
doctormord's Avatar
You may try lowering the gain of the TPA. If you can actually overdrive the amp with your BT source, then reducing gain is an option with good success.
Old 10th October 2017, 02:24 PM   #37
For now I'm listening music on min level of volume form my phone.
Old 10th October 2017, 02:25 PM   #38
doctormord's Avatar
Alright, then remove the resistor "753" near the TPA chip. This lowers the gain from 36dB down to 20dB.
(I might be neccessary to change the "433" resistor for a 10k ("103"), but remove "753" first and test)
Old 10th October 2017, 02:27 PM   #39
Ok I'll try. Only remove without bridging anything ?
Old 10th October 2017, 02:28 PM   #40
doctormord's Avatar
Just remove this resistor. (But don't break it)
TPA3116 + CSR8635 Idle NoiseHide this!Advertise here!
SANWU TPA3116 + CSR8635 Bluetooth 4.0 - Noise Fix doctormord Class D 212 10th June 2018 07:00 PM
Picking up too much digital noise with TPA3116 twomix Class D 30 6th June 2017 02:42 PM
TPA3116 2.1 + Little Bear P5 + noise Swiftmatt Class D 6 28th September 2015 07:54 AM
TPA3116 2.1 digital amplifier POP noise on/off mk4r34 Class D 0 13th March 2015 06:58 PM
How to fix idle noise on 50 year old Bang and Olufsen Alaza Solid State 11 10th July 2013 08:38 PM
