TPA3116 + CSR8635 Idle Noise
Old 26th September 2017, 12:35 PM   #21
theAnonymous1 is offline theAnonymous1  United States
theAnonymous1's Avatar
I'm thinking there's something wrong with the TPA3116 input components/layout. A 10k pot shouldn't have had much effect on the volume level.
Old 5th October 2017, 11:16 PM   #22
baklazanowy is offline baklazanowy
I took some hi-res photos:
Click the image to open in full size. Click the image to open in full size.
Old 5th October 2017, 11:19 PM   #23
@doctormord:
Could you point me where exactly should I solder 1500-2000 uF cap ?
25V or 35V of the cap?
Old 6th October 2017, 07:51 AM   #24
doctormord is offline doctormord  Germany
doctormord's Avatar
Seems like you only linked in the thumbnails?
Old 6th October 2017, 08:07 AM   #25
Strange...when I posted this reply, it works after click on thumbnails.
full res-photo:
front: http://www.mikomp.org/pcb/front.jpg
back: http://www.mikomp.org/pcb/back.jpg
Old 6th October 2017, 03:31 PM   #26
doctormord's Avatar
Best possible fix is like attached. Remove red marked components, solder wires in place like shown.
Drawback:
No volume control via potentiometer anymore
No Aux/Line-in (Aux might still work if they used the ADC of the BT-module.)
TPA3116 + CSR8635 Idle Noise-difffix_new-jpg
Keep the wires close together (R+/R- and L+/L-)
Old 6th October 2017, 11:20 PM   #27
Hello, many thanks for possible solution ! I will test it this weekend.
One question:
From point where (R+/R- and L+/L-) is marked I go directly to speakers +/- terminals (skipping connecting speakers cables to blue terminals on this board)
From what I understand I'm leaving after this solution option with adding capacitors.
Old 7th October 2017, 07:24 PM   #28
doctormord's Avatar
I dont understand your question.
Old 7th October 2017, 08:19 PM   #29
Where exacly should I connect speakers ? My guess: to colored dots near R+,R-,L+,L- ?
Old 7th October 2017, 08:59 PM   #30
doctormord's Avatar
To the output terminals as usual. The fix on the picture is to bypass the Linedriver between the bluetooth DAC output and TPA Input.
TPA3116 + CSR8635 Idle NoiseHide this!Advertise here!
SANWU TPA3116 + CSR8635 Bluetooth 4.0 - Noise Fix doctormord Class D 212 10th June 2018 07:00 PM
Picking up too much digital noise with TPA3116 twomix Class D 30 6th June 2017 02:42 PM
TPA3116 2.1 + Little Bear P5 + noise Swiftmatt Class D 6 28th September 2015 07:54 AM
TPA3116 2.1 digital amplifier POP noise on/off mk4r34 Class D 0 13th March 2015 06:58 PM
How to fix idle noise on 50 year old Bang and Olufsen Alaza Solid State 11 10th July 2013 08:38 PM
