TPA3116 + CSR8635 Idle Noise
Old 20th September 2017, 12:55 AM   #11
Perfdavid is offline Perfdavid  United States
With the board on, take a 3 inch piece of copper wire, like 1/2 of a speaker cable and touch it to the Bluetooth antenna. The squiggly line by the Bluetooth module. See if it goes away. If it does then solder it on. If it doesn't then That isn't the problem.
Old 20th September 2017, 05:43 AM   #12
baklazanowy is offline baklazanowy
The pot have B50K on the back.
Old 20th September 2017, 01:33 PM   #13
theAnonymous1 is offline theAnonymous1  United States
theAnonymous1's Avatar
Try replacing it with a 10K.
Old 22nd September 2017, 08:31 AM   #14
Tested, solution doesn't work
changing into B10K pot is universal solution?
Old 25th September 2017, 09:00 AM   #15
Hi, I changed pot to B10K, and the result is worse. Noise still exists and music is bearly audible...
Old 25th September 2017, 11:02 PM   #16
horst303 is offline horst303  Australia
yeah...
welcome to the world of ultra cheap amplifiers , the thing is that I doubt anybody makes these cheap modules for the purpose of selling to the diy market, they are all destined for a retail product of some sort, that means that the modules you get maybe genuinely surplus and perfectly fine, or they may just not pass quality standards, so as the product manager you suddenly have the choice, do you put them in the bin or on ebay/allie?
So here we are, now the fix maybe simple but you have to decide for yourself how much time and money, well mainly time, you are prepared to spend on a ~$10 board for what could be indeed a simple component fix, but could just as well be a fundamental design flaw.
FWIW I have a number of these tpa3*** modules with soldered on bluetooth board, and they are all unusable, now I can't say that the next one you get will also be bad, but your experience here and now just confirms my bias.
Old 26th September 2017, 07:09 AM   #17
doctormord is offline doctormord  Germany
doctormord's Avatar
Well, most boards can be fixed when patching the link from BT to TPA from pseudo-differential to full-differential. I showed this for 2 Sanwu boards.
Old 26th September 2017, 08:23 AM   #18
It's possible with multimeter and some basic electronic skills find solution for my problem ?
Old 26th September 2017, 08:34 AM   #19
doctormord's Avatar
Most likely not. I'll need high resolution pictures of front/back side of the board. (Sharp, without flash marks, straight)
One more thing to try, solder a big LowESR Cap in parallel with the yellow tantal cap right above the relay. Please note, die brown indicator on there is +++ while on Elytcaps the --- is marked. something like 1500-2000uF is a good start.
Patching the board for fully-differential most likely kills the aux-functionality.
Old 26th September 2017, 08:39 AM   #20
Ok, I'll try do some hi-res photos. I don't need AUX input.
Thx, I'll try with cap solution.
TPA3116 + CSR8635 Idle NoiseHide this!Advertise here!
SANWU TPA3116 + CSR8635 Bluetooth 4.0 - Noise Fix doctormord Class D 211 11th May 2018 11:39 AM
Picking up too much digital noise with TPA3116 twomix Class D 30 6th June 2017 02:42 PM
TPA3116 2.1 + Little Bear P5 + noise Swiftmatt Class D 6 28th September 2015 07:54 AM
TPA3116 2.1 digital amplifier POP noise on/off mk4r34 Class D 0 13th March 2015 06:58 PM
How to fix idle noise on 50 year old Bang and Olufsen Alaza Solid State 11 10th July 2013 08:38 PM
