What is wrong with TPA3255?
Old 10th November 2017, 04:58 PM   #161
vizeta is offline vizeta  India
I was not aware about the difference and ordered this board at cheapest price available. Though the list was for blue board but I received a black board
Old 10th November 2017, 07:13 PM   #162
JacobEO is offline JacobEO
A clear disadvantage to PFFB in the TPA3255 would definately be the need for a zobel resistor during open load configurations I'd say.
The improvement in idle noise would maybe be worth the extra components however.
Old 10th November 2017, 08:19 PM   #163
DPH is offline DPH  United States
However you need to increase the gain elsewhere to make up the difference. Just make sure whatever's doing that is quiet. (Unless you have excess gain in your system already, then you're good to go!)
Happy DIYing, Daniel
Old 10th November 2017, 09:31 PM   #164
lithoc is offline lithoc  Malaysia
lithoc's Avatar
Have you tested it?
Does it have pop sound when power up and shutdown?
Does it sound good?
Old 12th November 2017, 09:58 AM   #165
Nope! I have already received TI EVM and connected to Mean Well SMPS. I am planning to not use it and sell it locally.
Old 13th November 2017, 11:02 AM   #166
doctormord is offline doctormord  Germany
doctormord's Avatar
How would PFFB improve idle noise?
Old 13th November 2017, 04:47 PM   #167
PFFB -- If you can get away with the lower gain, the idle noise will decrease accordingly. If you have to turn up the gain elsewhere to make up for the PFFB, you're basically back to square one.
* I'd think this would matter only in the most extreme of sensitive speakers and/or ground loops. The former would be important for sound reinforcement (who needs this many watts PLUS super sensitive speakers for domestic hifi?!) and the latter should be addressed, not blamed on the amp itself.
Old 13th November 2017, 05:36 PM   #168
voltwide is offline voltwide  Ireland
no, that is not the hole truth. Idle noise can be reduced due to the fact that input referred noise of TPA3255 is something like
65uV/Gain = 6.5uV.(rms)
There are lots of OPAs with significant lower input noise.
Following this, you can reduce gain of TPA3255, compensate gain loss with a preceeding OPA and achieve a lower output noise at the same total gain.
In my private test setup I did demonstrate this achievement.
Old 13th November 2017, 09:08 PM   #169
Of course, Voltwide, I guess I should have provided the caveat that an inverting, 10k input impedance NE5532 (like the EVM but changing the feedback resistor) will have higher noise than the internal gain structure of the TPA3255, albeit marginally. Plenty of ways to go lower both on input impedance or switch over to something like an OPA164x (suggested due to DI process lowering CM distortion and jfet-input) and have a very high input impedance non-inverting topology. A direct swap from the NE5532 on the EVM to a OPA2209 would also lower the noise appreciably.
Old 16th November 2017, 01:37 AM   #170
ccss is offline ccss  United States
Originally Posted by KaffiMann View Post
I couldn't find any additional information about it, but in the pictures it looks like there is no earth ground (marked "NC", not connected, on the board), which means you could use it with a 2-prong power cord, but might need to be careful about grounding of input devices for your amp or you could have noise. Typical RCA outputs/inputs are earth-grounded but it depends on the source.
Also, it does not appear to be adjustable, which I guess means you get 48V and only 48V? For tpa3255, I like to run at 51V. And there's no PFC mentioned.
What is wrong with TPA3255?Hide this!Advertise here!
TPA3255 - all about DIY, Discussion, Design etc. lms Class D 692 15th June 2018 05:13 PM
My 1st Class-D Amp -TPA3255 with PFFB JohnnyInBris Class D 17 6th October 2017 06:25 AM
FS: TPA3251 TPA3255 2.0 BTL Amplifier doctormord Swap Meet 11 13th August 2017 07:14 PM
TPA3255 Amplifier for Car Audio System GABRIELITEDEVIL Class D 6 1st January 2017 09:37 PM
Wrong Voltage / current on BoZ... or Wrong Measuring ? gionag Pass Labs 8 14th May 2008 11:24 AM
