TI Class D EVM Board 50% Promotion
Old 15th June 2018, 03:59 PM   #261
doctormord is offline doctormord  Germany
doctormord's Avatar
Been there, done that but using 50V instead to have some headroom for the two SE channels. (Boosted from 37V)
Old 15th June 2018, 04:03 PM   #262
doctormord's Avatar
Originally Posted by dubai2000 View Post
I would like to try connecting the TPA3255 without its input stage - as suggested above. Before doing so I would like to know if that will be safe as (so it has been kindly pointed out to me) "on tpa3255evm whatever you do with the jumpers there is always a connection from the op amps to the last coupling caps and wrong grounding can damage the op amp." Can anybody shed some light on this issue as (obviously) I'd rather not fry the amp.
Thx in advance for your feedback.
This only works with a fully fidderential source for using the board in BTL. If you use the channels in SE, your source also needs to be single ended. You can't have your board running in BTL when using single ended input as the input stage does invert the signal for one channel to supply a differential signal into the TPA.
Old 15th June 2018, 04:42 PM   #263
mboxler is offline mboxler  United States
One could, though, run a SE signal through a 10UF cap straight to INPUT A, and run SE ground to INPUT B. Granted, the voltage across OUTPUT A and
OUTPUT B would cut in half, but the op amps would be bypassed.
You basically would have a SE output riding on a 1/2 power supply voltage DC offset.
Weird, but it should work.
Old 15th June 2018, 04:53 PM   #264
doctormord's Avatar
DC isnt something I want my speaker to have without a blocking cap.
Old 15th June 2018, 08:19 PM   #265
dubai2000 is offline dubai2000  Europe
Thx for the input - luckily the amps already sounds pretty good in its original form.
Old 15th June 2018, 11:55 PM   #266
hyped is offline hyped  Australia
Originally Posted by Yatsushiro View Post
On the contrary, no additional fees paid, delivery by FedEx.
I was amazed they are saying only 7usd for shipping to Australia!
Old 16th June 2018, 08:52 AM   #267
pguerin is offline pguerin  France
Originally Posted by Titu View Post
From TI :
I have to inform you that this EVM is one of our products that we no longer have on stock in Europe and due to recent changes of EU regulations cannot be currently imported from US. It has to be re-certified for the European market first, therefore, even if you place a new order the fulfillment might take even up to one year.
The only way to purchase this EVM is to check if any of our official distributors still has it on European stock: Electronic Component Search of Authorized Distributors | ECIA.
I can forget the 50%...
No email received from TI but I've ordered TPA3255EVM on June 11 and my order status is still "In Work at Fulfillment".
Has someneone got recently an EVM board from TI in France or Europe ?
FYI, the TPA3255EVM is available from mouser.fr.
BR,
Pascal
Old 16th June 2018, 09:22 AM   #268
Kay Pirinha is offline Kay Pirinha  Germany
Kay Pirinha's Avatar
Same from Mouser.de, at 139.78, no additional fees.
Best regards!
"Bless you, Sister. May all your sons be bishops." (Brendan Behan)
TI Class D EVM Board 50% PromotionHide this!Advertise here!
Free: Non-audio TI ADC board (TLC2543 EVM) rif Swap Meet 0 22nd February 2013 08:35 PM
TI 5518/5152K 8 channel Equibit EVM board - $100 dwk123 Swap Meet 2 12th August 2011 01:47 PM
Troubleshooting TI Class D EVM amp? fizzsweden Class D 4 18th July 2011 09:29 PM
ti 5709 evm jamey0824 Class D 3 13th April 2010 08:05 AM
TI tas5112 EVM - output filter mod? ChuckT Class D 0 5th January 2007 07:36 AM
