Amplifier for my pc loudspeakers
Old 18th June 2017, 05:07 PM   #1
bawde is offline bawde
Default Amplifier for my pc loudspeakers
Hi all, I would like to replace my Logitech 2.1 sound system connected to my computer with better loudspeakers and a subwoofer. I bought a cheap 8'' sub and have two Magnat Alu Needle satellites. Could you please help me and tell me what amplifier I should buy? As far as I understand, the TPA3116D2 should not be connected directly to the computer. But what should I connect in between? Thank you
Old 18th June 2017, 05:19 PM   #2
rayma is online now rayma  United States
Some boards, like this one, have the needed volume control built-in,
and can connect directly to the PC.
https://www.amazon.com/SMAKN-TPA3116...66QZSQSB3KTCST
Old 18th June 2017, 05:23 PM   #3
Can I recognize this on the built in volume controller?
Old 18th June 2017, 05:31 PM   #4
Not sure what you mean. If the board has at least one knob,
then it will have a volume control.
Old 18th June 2017, 06:14 PM   #5
Bigun is offline Bigun  Canada
Bigun's Avatar
For the computer to be able to control the volume of an external amplifier it would need to have a digital interface. This one linked above does not. You could use the volume control in your computer and keep the external one set at some convenient level. Or you could use the external control and leave the computer volume at some convenient level. The one that is linked above needs a case and a power supply though.
I would suggest you buy something all ready complete. Something that just needs a wallwart power supply.
For example (there are many if you search, but don't buy a headphone amplifier by mistake, it must state that it's suitable for speakers): http://www.ebay.ca/itm/Douk-Audio-TK...YAAOSwAoRXFaSd
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig.
Old 18th June 2017, 09:12 PM   #6
Ok thank you May I should buy this one https://www.amazon.de/Nobsound-TPA31...ords=TPA3116D2
Old 19th June 2017, 05:47 PM   #7
Hi all, is a 12V 3A power supply ok for the TPA3116? I got this power supply in my closet
Old 19th June 2017, 05:50 PM   #8
Osvaldo de Banfield is offline Osvaldo de Banfield  Argentina
Osvaldo de Banfield's Avatar
Location: Barrio Garay,Almirante Brown, Buenos Aires, Argentina
Can you accept a discrete solution?
http://www.diyaudio.com/forums/class...y-project.html post #3.
Osvaldo F. Zappacosta. Electronic Engineer UTN FRA from 2001.
Argentine Ham Radio LW1DSE since 1987.
Amplifier for my pc loudspeakersHide this!Advertise here!
Output Amplifier for Ribbon Loudspeakers ptashton Elektor 4 10th January 2016 05:05 PM
Suitable Amplifier for my loudspeakers nitinbose Solid State 3 25th November 2013 12:53 PM
Looking for 2.0 loudspeakers for PC as much treble as possible? jushmush Multi-Way 9 8th May 2013 10:30 AM
PC loudspeakers potentiometer problem michaelpage26 Parts 3 23rd April 2006 11:05 AM
Protecting loudspeakers in bridge amplifier alex0 Solid State 1 3rd May 2004 07:15 AM
