Want to run ~1200 watts of car amps in my home - diyAudio
Go Back   Home > Forums > Amplifiers > Class D
Old 12th May 2017, 06:57 PM   #1
Question Want to run ~1200 watts of car amps in my home
Hey folks, I've got three digital Precision Power amps that I'd like to run a temporary home theater speaker setup with.
I know I can just grab a PC power supply to run a small amp, but what should I do about ~1200 watts?
This will be for front & rear speakers along with a pair of 15" vented subwoofer enclosures.
I'm in the USA.
The source will be my HTPC computer with a Sound Blaster "Z" audio card (3.5mm x3 output for 5.1 audio).
Old 12th May 2017, 07:05 PM   #2
quite simple, get a larger truck battery, hook em up and good to go.
allso grab an automatic charger. before you turn your system on, simply disconnect the charger. and when you are done with your movie, re-connect the charger.
V*A=VA
V*A*PowerFactor = WATT
Old 12th May 2017, 07:07 PM   #3
HumbleDeer's Avatar
For one: Don't. At least, don't power them at full power with a wanky pc power supply.
If you do want to do it, get yourself some beefy LINEAR Power Supplies that can handle all the amps. Just because switch mode power supplies can and WILL blow up in your face when parallelled. Because, you just don't. If you do have to use switch mode ones, use switch mode psu's from the same make, same batch, same date. Preferrably server psu's that are MEANT to be able to be ran parallel. Barevids did it. Loud junk though.
Your sub won't need 1200watts (probably peak though-) to be home theatre ready, right?
Hope this is a bit of help.
Old 12th May 2017, 07:41 PM   #4
OffGridKindaGuy's Avatar
Math says.. 100 amp supply @ 12 v.d.c. You're gonna need every bit of that during an action scene..
Old 12th May 2017, 07:50 PM   #5
Probably not, as the 1200W will be mostly imaginary - but still, a truck battery (or even a decent car battery) with a charger is likely to be the cheapest option.
Nigel Goodwin
Old 12th May 2017, 08:31 PM   #6
I agree. The stated/rated power is usually half. (The big sham) But still, during action scenes, the 3 amplifiers would still require at least ~50 amps, I'm sure, with the subs being the power hogs..
I seriously don't believe a car battery would last a whole movie..
Old 13th May 2017, 03:55 PM   #7
I´ve done just what you are asking.
I connected two equal computer PSUs together in paralell to get a total of 12v 60A. It worked like a dream, but I would rather recommend to get yourself a server PSU. They can often deliver 12v up to 120A+ (1440W) so plenty of power. Many people in the RC community uses these server PSUs to charge their batteries etc. Search around, there´s a lot of good info on them, and a lot of then floating round on ebay. You might even be lucky to scrap one form an old server form the dump
Old 16th May 2017, 11:58 PM   #8
for 1000s of watts, search on 2rd hand sale sites like evilbay for server power supplys. like DPS-something. look for instructions on how to active them on https://www.rcgroups.com .
Old 17th May 2017, 11:01 AM   #9
dzwer is offline dzwer  Bulgaria
dzwer's Avatar
It's better to use 3 PSUs - one PSU per amplifier.
Nothing moves you like a hydropneumatic Citroen...
Home audio watts vs Car audio Saaif88 The Lounge 53 3rd May 2017 11:52 PM
ucd 25 watts to 1200 watts using 2 mosfets andrewlebon Class D 4592 29th April 2017 04:52 AM
car head-unit to run home power amplifiers tinkerbell Everything Else 1 29th December 2006 11:31 PM
Sound quality of amps at 0.3 watts vs @ typical 5 watts rick57 Solid State 2 26th March 2005 06:25 AM
How many watts a usual car cassette player? robin2d Car Audio 5 24th September 2004 08:48 PM
Copyright ©1999-2017 diyAudio
