amp6 41hz silent on one channel back up after power cycling - diyAudio
Go Back   Home > Forums > Amplifiers > Class D
Old 2nd April 2017, 09:31 AM   #1
Default amp6 41hz silent on one channel back up after power cycling
Dear all,
First of all, I hope this is the correct part of the forum for the question.
Some years ago I build a amp6 kit from 41Hz. It is presently used with a set of home-build speakers and I like the way it sounds but have a problem with one of the channels. It will quite often go silent and come back up after power cycling.
Reading the data sheet of TA2020 I don't think there is a one channel protection system, so does any one have an idea of what I should look for trying to track down the problem?
Another small detail, the same channel that goes silent also has some static when moving the volume pot without any input.
All ideas welcome.
best regards
Joa
Old 2nd April 2017, 10:46 AM   #2
ICG is offline ICG  Germany
The TA2020 indeed has only one protection for over temperature, over current, under voltage and mute cicuit.
Due to recent public demand, the light at the end of the tunnel will be turned on 7:00 to 23:00 weekdays and 9:00 to 2:00 on sa and su. And stay out of the ladies room!
Help with a poorly 41hz Amp6 ambientvoid Class D 4 17th June 2016 09:28 AM
FS: 41hz amp6 Basic Assembled + Power Supply nic6paul Swap Meet 5 22nd May 2014 02:19 AM
power supply for 41hz amp6 basic bull041161 Class D 3 27th April 2009 09:44 PM
Power transformer for 41hz amp6 ecl86 Class D 7 27th June 2007 10:06 PM
41Hz Amp6 cadbike Class D 9 8th January 2006 04:30 PM
Copyright 1999-2017 diyAudio
