My 1st Class-D Amp -TPA3255 with PFFB
Old 6th March 2017, 09:50 PM   #11
mantabernd is offline mantabernd  Germany
Perfect thanks.
Old 6th March 2017, 10:43 PM   #12
doctormord is offline doctormord  Germany
doctormord's Avatar
Originally Posted by mantabernd View Post
Nice work!
In my design this snubber dissipates a lot of power and sometimes even dies if amp
clips without load. I need to replace the R then... But I'm actually using 1.33uF + 3.3 Ohms so corner frequency is a bit lower in my design.
What do you expect, do a simulation and see for yourself. It's totally normal without any bw-limit on the inputs. With values from application note, the snubbers resonance frequency is at about 47kHz.
Been there, done that:
http://www.diyaudio.com/forums/class...ml#post4987732
30A current in the snubber.
Old 13th March 2017, 02:20 AM   #13
JohnnyInBris is offline JohnnyInBris  Australia
Perfect thanks.
With no load and with audio signal levels just below clipping there is no heating of the snubber resistors. I would suggest that there may be a HF instability in your design or that you are testing with unrealistic signal levels in the 10s of KHz region
Old 13th March 2017, 05:27 AM   #14
Thanks for checking this in your design.
It only happens when the amp clips. Shortly before clipping it's all ok.
And no, my test signal was 1kHz sinus.
But actually I could solve this problem already by compensating the post filter feedback loop. It's stable now even with no load.
My phase shift is now between 15 and 45.
Old 6th October 2017, 12:57 AM   #15
JonesySA is offline JonesySA  Australia
Have you used the SMPS much? Would you recommend it?
Old 6th October 2017, 02:15 AM   #16
I've used both linear and SMPS and I can't hear any difference except for fan noise in the SMPS
Old 6th October 2017, 05:38 AM   #17
Could you link to the one you purchased? I'm interested in alternatives to the Meanwell which can be dearer in Australia.
Old 6th October 2017, 06:25 AM   #18
free shipping 360W 48V 7.5A Switching Power Supply Driver for CCTV camera LED Strip AC 100 240V Input to DC 48V output-in Switching Power Supply from Home Improvement on Aliexpress.com | Alibaba Group
My 1st Class-D Amp -TPA3255 with PFFBHide this!Advertise here!
TPA3255 - all about DIY, Discussion, Design etc. lms Class D 692 15th June 2018 05:13 PM
FS: TPA3251 TPA3255 2.0 BTL Amplifier doctormord Swap Meet 11 13th August 2017 07:14 PM
TPA3255 Amplifier for Car Audio System GABRIELITEDEVIL Class D 6 1st January 2017 09:37 PM
1st Pass at 1st Phono Preamp; Comments? nullspace Tubes / Valves 16 1st December 2009 08:47 PM
1st time DIY Class A jab23 Solid State 18 23rd March 2002 11:52 AM
