Hypex UcD Build Problem with Hum
Old 12th February 2017, 07:57 AM   #11
ds23man is online now ds23man  Netherlands
ds23man's Avatar
http://www.diyaudio.com/forums/attac...1&d=1486889797
Old 19th February 2017, 07:52 AM   #12
raelman is offline raelman  Spain
Hello.
Will be the hypex UcD xxxLP OEM converter board a solution?
I don't know if those boards have input buffer, but should be.
Isn't that?
Btw, Doritos123, what kind of opamp did you used?
Maybe I will build something with those lp boards.
Old 19th February 2017, 09:10 AM   #13
ds23man's Avatar
Those boards are OEM only!
Old 19th February 2017, 09:21 AM   #14
I can buy oem
Old 20th February 2017, 04:03 PM   #15
doritos123 is offline doritos123  Netherlands
The converter board doesn't have input buffer.
And Hypex doesn't sell the OEM parts to consumers.
I now use the LM4562.
After fixing my RCA to XLR cable, the hum is now gone.
I am now in the process to build the input buffer with a nice PCB.
And finally (and hopefully) assembly the amp.
My target is a 6 channel amp in one chassis.
4x UcD250 with 4x LM4562 input buffer
2x UcD400
1x SMPS1200A400 (suppy all the UcDs)
1x SSR04 Super Regulator (supply the input buffer)
This is actually a big project for me to tackle. So might take some time.
But i keep learning from this forum.
Old 9th February 2018, 06:19 PM   #16
kjb is offline kjb  Sweden
Hello. Did you ever got to making a pcb for the input buffert?
Linkwitz Lx521.4, Seas Mimir, ME2
Hypex Ucd250LP, Ucd400OEM, ESP P3A
Old 12th February 2018, 06:40 AM   #17
Antana is offline Antana  Europe
Originally Posted by raelman View Post
Hello.
The UcDxxxLP converterboard is nothing more than a PCBA that makes the 16P header easily accessible for quick evaluation. It does not contain a buffer, only some LED's.
Since your are an OEM yourselves, I suggest you design your own input board, basically the OEM converter with opamp, possibly trigger input or whatever you want. If you wish, you can post your design here and request a review.
Hypex UcD Build Problem with HumHide this!Advertise here!
Hypex UCD400 hum problem tube pre volvoturbo Class D 31 7th April 2015 09:21 AM
Getting the best out of Hypex UCD lotuss79 Class D 15 22nd November 2014 06:07 AM
Would like to try and build a Tube pre/Hypex UcD 400 power unit for Light weight bass rim basses Class D 9 25th February 2009 10:34 AM
Hypex UcD 180AD + signal wires, Power Supply ST, Hypex Transformer TR100A c10h12n2 Swap Meet 7 7th July 2007 03:55 PM
FS: Hypex UcD 400/180AD, hypex toroid Archmage Swap Meet 4 14th November 2006 04:23 AM
