yes, but i think the Italian customs have special skills. they choose the amount, and there is no way to challenge it.
i once paid 60 euros import duties on a 40 euro usb tv tuner from China. (the piece was basically unique and no equivalent available in Europe, so i bit my tongue and paid)
since then ive always tried to find sellers within the EU. very frustrating when you can see the price paid outside EU.
3eAudio, I have got a TPA3251 board last week and I am trying it out now. Its a wonderfully well made board.
I had a question. The board says that it needs a power supply of 24-36 volts DC. My PS gives out 39 volts DC. Can I feed 39 volts to the board?
Data sheet says 36 typical, 38 max.
Does your PS have a potentiometer to lower output voltage? Usually 10% is the range.
No, it doesn't.
im using a sure boost converter, great for battery running i hope . still wiring/boxing mine up
Sure Electronics' webstore 500W BOOST Converter for CAR Audio - TL494
Where did you find this board, it has disappeared from eBay.Hi,
I received this board last week (it looks nice ). I need buy power supply. Is MEAN WELL LRS-150-36 good choice or I must buy HRPG-150-36 with constant current limiting circuit?
150W is a bit on the low side -> LRS-350-36
Thank you for your reply. I can not find any LRS-350-36 in czech shops. Maybe it is old version without PFC. I don't know. I choose MEAN WELL PID-250C, it have 250W without fan. I live in flat, I don't need full power this board. This smps have two outputs 36V and 5V output. Integtrated 5V output is advantage for me.
It's difficult with 3e-audio.com. They official webpage is disable for half of world. You can check it at Website Availability Test - Uptrends. Ebay account don't show relevant goods for banned countries. I talked with 3eaudio member via diyaudio private messages. He or she reply me quickly. It is some trouble with china post.
I used german VPN. Buy it on ebay like guest. Send it to Germany and resend to Czech. Resend was cheep about 6 euro.
Not sure what the schematic is for this board but 100k during in front of an inverted buffer is a lot high and noisy. Need to check the feedback resistor as well.
The lrs power supply does not have pfc.
Hi DPH
Attached is the schematic for the frontstage.
I would change the resistor to approx 15k to make my 100k lin pot into a "fake" log, but i am unsure if it is messing som other things up.
- Class D
- TPA3251 2Ch Amplifier Board DIY Design (Compact size/Amazing Performance)
