TPA3116 2.1 LPF sounds like a mess - diyAudio
Go Back   Home > Forums > Amplifiers > Class D
Old 27th January 2017, 08:55 PM   #1
Xappys is offline Xappys  United Kingdom
Default TPA3116 2.1 LPF sounds like a mess
Hello,
I'm building cheapish 2.1 set for PC usage (2 satelittes and 6" sub). I have TPA3116 2.1 from ebay which I could use but the LPF is at horrible frequency!!! It's about 1Khz by my estimations. Is there any relatively easy way to modify it to something like 150Hz? I can write some values of components if needed ...
Any replies welcome
Old 28th January 2017, 10:40 AM   #2
schematic please.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 28th January 2017, 03:53 PM   #3
I'll try to find it in web ASAP.
Old 28th January 2017, 06:30 PM   #4
I've spent many hours searching for schematics with no luck.
But well, I found an area which seems to be LPF stage. I hope it helps you to help me
Here are the values of numbered parts in photos: https://postimg.org/gallery/1lgq5dqea/
1. 47K
2. 33K
3. 33K
4. 47K
5.47K
6. 47K
7. unknown, tried measuring - numbers are slowly dropping and uneven.
8. 47K
9. 47K
10. 47K
11. 0.056uF
12. 0.056uF
13. NE5532
14. NE5532
15. measured - seems to be 33K
16. measured - seems to be 33K
Thank you !
Old 28th January 2017, 07:16 PM   #5
7 is probably a 0.1uF capacitor.
Old 28th January 2017, 07:33 PM   #6
I'm pretty new to filters and stuff, but isn't it two stage 24db/oct active LPF? If you could approve that, I might look for some formulas to calculate new resistors' and capacitors' values.
(Although it can't be that simple, can it?)
Old 28th January 2017, 07:46 PM   #7
Without knowing the connectivity, it is hard to speculate.
Old 28th January 2017, 07:50 PM   #8
Then I'm continuing my search for schematics. So many same type boards but no single schematic found yet ...
What is this mess on the PCB? ShinOBIWAN Solid State 16 25th January 2016 02:55 AM
A complex mess namesmeanlittle Multi-Way 25 31st July 2014 12:06 PM
LM4870 Noob mess up littlerick Audio Sector 77 7th November 2010 01:12 PM
Help Please Guitar Project Mess Trout Instruments and Amps 7 15th September 2005 04:45 AM
Classification Mess Up freedom Solid State 2 15th November 2004 05:32 PM
Copyright 1999-2017 diyAudio
