Fullbridge Class D PA ultra high power - Page 5 - diyAudio
Go Back   Home > Forums > Amplifiers > Class D
Old 13th January 2017, 05:04 AM   #41
kartino is offline kartino  Indonesia
kartino's Avatar
Actually it is very easy game.
If you want over load protection at the situation, it is very simple, put thermal switch on the heatsink. Finish your problem, not my problem.
I only consider high possibility to happen, not all bad things. I know what you mean. But I don't consider that as that is no way someone to turn on the amp with no signal but have bad luck with output shorted. A double jeopardy.
Old 13th January 2017, 08:10 AM   #42
stewin is offline stewin  Kenya
hi pafi will this circut work comfortable with +/- 85vlts with a 2ohms load ?? outputs fets are irfb4227
Old 13th January 2017, 11:54 AM   #43
Pafi is offline Pafi  Hungary
85V and 2 ohms is possible for irfb4227, but no headroom, and there is no protection in this sch, and
- I can't find the gate driver PSU (not on schematic)
- bootstrap voltage is not hold correctly during positive overdrive. 3 ms max, it is dangerous.
- turn on is very slow. Good enough only for bass.
- clipping point is much lower for negative.
- Opto pairing is not indicated. :-(
- offset voltage setting is terrible.
should I continue checking it?
Old 13th January 2017, 12:07 PM   #44
jazbo8's Avatar
The OT posts have been removed, and kartino has been given a 50-point infraction for being disrespectful to the other members.
Old 13th January 2017, 02:06 PM   #45
kartino's Avatar
How about Pafi?
He started right?
Old 13th January 2017, 02:08 PM   #46
kartino's Avatar
I am waiting a fairness
If not.... sorry I am done with this forum
Old 13th January 2017, 02:15 PM   #47
nice
The Wire - Low Power Ultra High Perfromance (LPUHP) 16W Power Amplifier opc Solid State 744 2nd December 2016 03:32 PM
LF: The Wire - Low Power Ultra High Perfromance (LPUHP) 16W Power Amplifier jtktam Swap Meet 0 3rd May 2012 10:59 AM
ULTRA-high frequency driver impedance vs. Class D amps? head_unit Multi-Way 8 22nd January 2012 07:37 AM
fullbridge carrier class d ideas Tekko Class D 12 25th March 2011 09:00 PM
Fullbridge DIY High power Sub amp? Ryssen Class D 4 30th July 2010 03:04 PM
Copyright 1999-2017 diyAudio
