Sure Electronics AA-AB32313  2x400
Old 12th January 2018, 04:58 AM   #291
JohnnyInBris is offline JohnnyInBris  Australia
The AA-AB32313 data sheet specifies a 33K input impedance and -3db at 20Hz so their input capacitor is more like 0.22uF. I'm thinking that increasing the value of Ca (BIASCAP pin on TC2001) will likely resolve the turn-on pop
Old 12th January 2018, 07:22 AM   #292
selwe is offline selwe
For the turn on pop I think a cheap protection board could be connected on outputs. I'm not sure though that any DC protection board would work for this kind of amp (single power supply, BTL). I've bought a UPC1237 based board from ali and it comes with one second delay start (before it connects the speakers via relays). Again, I'm not sure the DC detect function works for this amp topology.
Old 8th February 2018, 07:26 PM   #293
AA-AB32313 vs. a good TPA3255 implementation?
Old 9th February 2018, 01:08 PM   #294
ICG is offline ICG  Germany
ICG's Avatar
I've waited quite a while for someone else besides sure/wondom to sell amplifier boards with the STA516/STA508 ICs and I finally found some on eBay. They are very reasonable priced and I'm extremely tempted to order the smaller one, for that price there's not much risk. I have to say I don't know anything about these amps, haven't heard them and don't know anyone who has. Does, by chance, anyone on here already got hands (erm, ears ) on them?
YJ STA516B 2.1 320W+160W+160W 4ohm Class D Amplifier Completed board | eBay
STA508 + TC2000 2.1CH Class D Amplifier Board Amp 2*80W+160W (Beyond TPA3116) | eBay
I had a Déjà Moo - I've seen that BS before!
Old 9th February 2018, 08:29 PM   #295
bih is offline bih  Switzerland
I got both of them. But the TI chip is on a cheep board and it sounds not so good like the wondom. Perhaps the EVM sounds better, but cots 3 time the chineese board.
My wondom has 2,7u Mundorf caps and sounds with my tube buffer perfect.
HP
Old 9th February 2018, 09:17 PM   #296
ICG's Avatar
HP
Thank you very much. I already got one Sure amp but I need 2 more channels and I thought I could maybe get away a bit cheaper. I switched the input caps too, mine are Panasonic ones, I can confirm, the improvement is clearly audible. Maybe these boards can be easily tuned too but I think I'll instead just go for another Sure/Wondom one. Again, thank you for the information.
Old 9th February 2018, 10:06 PM   #297
pistollero is offline pistollero  Portugal
Hello... i have the wodom plus the meanwell 36 volt ps.. i feel the sound too soft...
Anyone experience this?
Change the input caps too.. jantzen superior z 2.2..
The sound is too soft for my taste...
Old 9th February 2018, 10:15 PM   #298
ICG's Avatar
The input cap changes/imprives the clarity, details and if you go for a higher value, it extends the bass. If you want more 'polished' treble, bit more 'bite', modify the output filter inductors (lower inductance) since that filter interacts - like on every class D amp - a lot with the speaker impedance.
Old 9th February 2018, 10:52 PM   #299
I will try that.. i m using 3way jbl 8ohm speakers..
I don t have that strong thunder bass.... and highs are softer too... first time i power it up.. i was expecting a lot of Power. coming from a 15 watts amp i do not feel such a difference.
Old 9th February 2018, 11:07 PM   #300
ICG's Avatar
I will try that.. i m using 3way jbl 8ohm speakers.. I don t have that strong thunder bass.... and highs are softer too... first time i power it up.. i was expecting a lot of Power. coming from a 15 watts amp i do not feel such a difference.
On 8 Ohm they don't have that much power. The specs say clearly the power is reached at 3 Ohm. And it's ofcourse dependent on the power supply voltage. The power supply itself got a lot to say on how it sounds too btw. At which voltage are you using your amp? What kind of PS are you using?
Sure Electronics AA-AB32313  2x400Hide this!Advertise here!
Sure Electronics AA-AB32281 2x200W wdecho Class D 16 3rd November 2016 10:58 AM
Sure Electronics AA-AK32151 - Assembled class D amplifier with cigar box case $25 obo JZatopa Swap Meet 2 25th June 2016 09:01 PM
Sure electronics ST508 amp: AA-AB32186 CCU Chip Amps 7 5th October 2015 09:54 AM
Sure Electronics AA-AB33182 [4 x 100W] Class D Audio Amplifier Board +27V DC Power... fualcr Swap Meet 5 11th December 2014 08:32 PM
FS: HIGH END Home Audio lot..Opera Louspeakers, Triangle Comete, AA Primo, AA, etc. JiggaD369 Swap Meet 6 22nd August 2008 01:32 AM
