Sure Electronics AA-AB32313  2x400
Old 28th September 2017, 07:19 PM   #231
denbret is offline denbret  Canada
denbret's Avatar
Originally Posted by selwe View Post
Is here anybody who tried AA-AB32313 / WONDOM AB23251V120
against
Hifimediy T4 / T3S
I had the T4, the sound is aggressive and I have now the 2x400w and no comparison.
Old 29th September 2017, 08:58 PM   #232
selwe is offline selwe
Thanks for sharing this useful info
Old 14th November 2017, 06:31 PM   #233
clawmd is offline clawmd  United States
Default PSU
Dose anybody have a recommendation for a small form factor SMPS. An enclosed MeanWell SMPS is huge, requiring a very large case to fit both the amp and the PS. MeanWell makes A number of models with an "open Frame" that are much smaller. Would one of these work?
Old 30th November 2017, 07:44 PM   #234
Cantunes is offline Cantunes  Brazil
Hello everyone, I found these cards on Aliexpress. Are they Sure Originals?
I have seen other cards the same as Sure, but they are offered by the name WONDON.
I was interested in buying, but I'm afraid of being fake.
Classe D amplificador de potencia digital de alta potencia terminou bordo febre canal 2 500 w + 500 w T Amp estagio casa em Circuitos integrados de Componentes Eletronicos & Suprimentos no AliExpress.com | Alibaba Group
Old 30th November 2017, 09:14 PM   #235
JohnnyInBris is offline JohnnyInBris  Australia
I purchased AB32313 from ebay seller sure-hifi and it's advertised as wondom. The ebay listing shows the business as sure electronics
Old 30th November 2017, 09:28 PM   #236
Thank you Johnny! Now I feel more secure.
Old 30th November 2017, 11:10 PM   #237
Frabor is offline Frabor
Default Ali supplier, Power supplies and second revision
Cantunes: The board look original, even to small levels on the silkscreen, so I would say that they are good. It seems that there is a rev2 of the AB32313, so make sure that you are getting the new one.
strongbow60: Looks like yours is the new revision/
clawmd: i have the AA-AB3151 1x500W version of the board and I am tunning mine with a minidsp and HLG-150H-36 set at 40V. I run tests with a bigger power supply and with test tones at 1000Hz at the fill .9 Volt output of the minidsp, the amp was consuming about 3 Amps. , so that power supply was enough. If you want an open frame look in CNC supply shops for 48 Volts power supplies.
I decided to use two of the the AA-AB3151 1x500w modules and two of the HLG-150H-36 to create a dual monoblock system. If you run the numbers, you can see that costwise is basically the same price as the AB32313.
Old 1st December 2017, 09:23 AM   #238
Thanks!
Old 3rd December 2017, 12:15 PM   #239
hopkins is offline hopkins  France
I tested the Aa-ab32313 and while it is quite good I did not find it better than the Hypex Ncore which have a more refined sound IMO.
Old 3rd December 2017, 01:59 PM   #240
ICG is offline ICG  Germany
ICG's Avatar
They are in the same league, hypex sounds better though. But keep in mind, you pay several times more than what the Sure/Wondom costs.
I had a Déjà Moo - I've seen that BS before!
Sure Electronics AA-AB32313  2x400Hide this!Advertise here!
Sure Electronics AA-AB32281 2x200W wdecho Class D 16 3rd November 2016 10:58 AM
Sure Electronics AA-AK32151 - Assembled class D amplifier with cigar box case $25 obo JZatopa Swap Meet 2 25th June 2016 09:01 PM
Sure electronics ST508 amp: AA-AB32186 CCU Chip Amps 7 5th October 2015 09:54 AM
Sure Electronics AA-AB33182 [4 x 100W] Class D Audio Amplifier Board +27V DC Power... fualcr Swap Meet 5 11th December 2014 08:32 PM
FS: HIGH END Home Audio lot..Opera Louspeakers, Triangle Comete, AA Primo, AA, etc. JiggaD369 Swap Meet 6 22nd August 2008 01:32 AM
