Need help with buying amplifier board
I need a amplifier board that can deliver a 500w rms in 8ohm. What can you suggest me for that, i need also a smps and speaker protection.I will make a amplifier with two boards so smps must be strong. Can you give me some idea or links where to buy some thing like that. Every answer is welcome. Thanks
I need a class d amp module
Have a look at Connexelectronic
High quality products . Several SMPS's have build in DC protection .
You could use 2 IRS500SMPS with build in SMPS and protection , OK "only" 300 Watts in 8 ohm . If you need more power , use 2 cheap IRS2092 4 ohm modules in Bridge mode per channel with the Balanced Input Phase Shifter , no bus pumping problems and use one of the SMPS's designed for that module . Used their products daily for several years now , not one problem !
Cheers ,
Rens
doctordata what do you think about ljm amp modules? Which of them to buy and make a btl connection? And which SMPS? Thanks
Hi Stule ,
I made a 5 channel AV amp a couple of years ago with 5 LJM's L15D's combined with Emotiva UMC-1 processor . Very happy with the results , sounds very good ! I use a 2000W SMPS from Connex and it's a very good combination ! Use it daily .
You could use 2 L15DPro with build in DC protection in BTL per channel .
I would go with 800W SMPS +/- 50V per channel with 10.000 microF extra buffer capacitors per rail , gives you 500 clean Watts in 8 ohms .
You'll need a phase inverter to drive them in bridge mode . See http://www.diyaudio.com/forums/clas...-irs2092-irfi4020h-200w8r-38.html#post2951879 or Connexelectronic
Cheers ,
Rens
