Go Back   Home > Forums > Amplifiers > Class D
Old 2nd March 2004, 02:36 AM   #11
wrenchone's Avatar
Most linear AB amps won't like working continuously in saturated mode very much - they may even overheat and blow up, depending on the outout drivers that are used. Most linear amps take their own sweet time coming out of clipping because of storage time effects in the driver (and output, if bipolar) transistors. You really want to build an amp optimized for switching operation.
Old 2nd March 2004, 07:05 AM   #12
IVX is offline IVX  Russian Federation
IVX's Avatar
Hi lumanauw,
why you want to force class AB (why need bias) for working as class D? ( a cow could be flying?) For any of class D experimentation simplest solution is a power comparator (lm319+ir2110 etc). If you'll be have such power comparator, then one week be enough for checking several basic class D circuits. But anyway UcD is most cost effective approach, IMHO. Sound & specs just fine.
Best regards,
E1.
Old 2nd March 2004, 10:09 AM   #13
diyAudio Moderator Emeritus
No, I wont push bipolar class AB to get this self oscilating class D. The amp will be more like Nch mosfet amp (Class D likes mosfet). This will be the perfect one, just to add big LC filter at the output and take the feedback after LC
Old 2nd March 2004, 10:19 AM   #14
BTW, that is not my design. I found it here in DIYAUDIO.
Anyone can explain why we need R2, Q1, Q2 in that configuration? Wouldn't it formed a differential? Why the author do not connect emitors of Q1 and Q2 directly to upper rail? Why he forms a differential? What is the merit of this configuration in this particular cct?
Old 2nd March 2004, 03:14 PM   #15
subwo1 is offline subwo1  United States
subwo1's Avatar
One reason for R2 is to prevent those transistors from going into saturation which would make their response very nonlinear, and cause lots of distortion. It also would help to smooth the crossover between mosfets. But when I experimented with that circuit years ago, it was quite distorted. Also, that type of mosfet drive definitely is way too slow for class D.
USMPS
http://groups.yahoo.com/group/switchmode/
How about a round-up of Class A kit power amps, or collectable vintage class A? Brisso57 Solid State 4 14th February 2007 10:30 AM
How to create self oscilating SMPS luka Power Supplies 10 7th January 2007 06:41 PM
Aleph P oscilating or something else!!! bbakota2000 Pass Labs 4 30th August 2004 04:17 PM
oscilating in capacitive load borisov57 Solid State 3 24th January 2003 12:29 PM
Page generated in 0.09060 seconds (70.00% PHP - 30.00% MySQL) with 11 queries
