what D amp give best sound.
Old 29th November 2017, 08:25 AM   #61
kees52 is offline kees52  Netherlands
I have to try it, I do soon, now I am busy with work. I do not now if with simulation the square test will work properly, I do have to look at output.
I had also try a model from @analogman however with a dead time generator with xor ports I still get shoot throughs, for what concerns the high end distortion, these people has such demands, otherwise you can not sell it to them, if you hear it or not. Class d is less simple as we think, the deadtimes needs to be very tight, and as such we need a very fast transitions or speed, I did try a emittor followed totem driver and a single totem driver, the first did very well driving big mosfets with high gate capacitances..
Adding more poles do not go without trouble, there is a border for how far you can go, but it do work very nicely, I do also use a fase network on the output and a 12 dB octave bessel low pass..
Old 29th November 2017, 08:31 AM   #62
I did try a deadtime on this schematic, however it do not cancel out the shoot through, I think the IR2011 model is not oke, also because I get less negative swing as positive and the square do not look oke.
I have now a model of a IRS20954 who has dead time in it, and a single input, that is more easy to use, did hear it is more sensitive for pcb design, but that is with all high speed switch designs.
Last picture is without the dead time and the first with, it looks like things are reversed so the dead time do not work, it even give more shoot through.
Old 7th December 2017, 05:02 AM   #63
Grizlek is offline Grizlek
I have to find schematics that I use.. Completely remove output stage it will be faster simulation.. and instead of fets use voltage controlled voltage sources, dead time can be generated using RCD circuit (any dead time you want), and delay can be manually added by transmission line. (any delay you want) ... Remember me to post in next days...
Dead time will not prevent shout through and instability.. dead time is 50- 100 nS.. instability lasts at least 2-3 periods of pwm signal..
Like I said "Russian metthod" they probably copied original hypex from Bruno is better (but havent tried it) ...
Old 7th December 2017, 02:45 PM   #64
days...
Like I said "Russian metthod" they probably copied original hypex from Bruno is better (but havent tried it) ...[/QUOTE]
You did give me an idea.
I have done the discrete comparator, this was from internet and with dead time I get this, and low distortion. The choise of the opamp integrator is very important, speed is needed for a clean output square.
regards
Old 8th December 2017, 12:55 PM   #65
regards[/QUOTE]
Forum member Sous (dont know if russian or indonesian) there was a link to russian forums. huh..
all in all feedback is advanced integrator with special circuit for preventing selfoscillation and instability.
This method full differential UcD modulator with extra integrator
Use single (non differentical) at the begining.. Try to simulate, you will get very low thd, but it will be very unstable if modulation is 60V peak and supply is 80 V peak.. only low pwm modulations are stable. Special circuits that shorts some pole/zeroes of integrator are needed. The same method uses Bruno Putzeys and hypex.
Maybe Sous schematics and design is free ?! But there was link to russian forums there full schematics give.. try to find and post here if you can (I had no luck)
Here you can see how transistor network shorts additioanl poles/zeroes of integrator. Have not tried with this in spice. This method is better and more stable then you posted. thd is below 0,001 (all powers) etc..
http://www.diyaudio.com/forums/attac...d_mdr-4_09-gif
here is it
Automotive UcD high-quality power amplifier 2x100W
????????????? ????????????????? ?????????????????? ?????? ????????? 2?100?? - ???????? 3
Viewer for layout and schematics lay files in zip folder
KOSTENLOSE DATEI-VIEWER, ELECTRONIC-SOFTWARE-SHOP
Old 9th December 2017, 09:47 AM   #66
I did this one also, but is from somewhone else, it is like with normal amps, the ideas are look alike, the combination is what matters.
I am a analog amp designer, combiner, class D not yet done really, but it is nice to play.
I had a idea also to do a open loop version full bridge, but I did see that it is not easy, likely very unstable also, I do not now that a ucd with feedback before the low pass can be considered open loop? I think I can not compare the feedback loops with analog amps where feedback do inpack audio depth, that is why I do use current feedback there, independent of bandwidth is a very good thing, special for imd, Designers going digital to try to do no feedback slowly get furter to working one, the designs who work do not sound wel yet as I did read on internet.
Last picture is a discrete power comparator with under 100nS speed with the right parts, special the output mosfets, a same one I did replace the upper and lower driver for a emmittor followed totem pole, it makes even nicer square on higher frequency, see the low pass filter who has multiply poles and a fase correction network on output I had this idea from the internet, it is not complete mine idea, as I say earlyer everything is alrweady tested by university people or designers from big electronic companys, switching amps was already present in 1950.
As what I do now now, speed is mandory for a low distortion, the poles needed for stability, or even to much works against us afcouse, it is a modulated carrier so as with FM radio it needs much attention for liniarity.
Old 11th December 2017, 11:39 AM   #67
But is not this approach better then this method you used in the first place (with LC filter phase correction) which is not stable ?
This method presented Sous seems much simpler, achieves better thd and even more stable..
But you did not try to incorporate "transistor network" which is used for stability, see below ?
Old 11th December 2017, 01:24 PM   #68
The fun afcouse to do it myselfs, otherwise I have no fun, so combine the things.
The fase correction version looks stable, when bridge these it does give a nise stable output where the voltages are correct. see picture
For me it is just learning and testing, not yet plans to build, I do work on the analog amp and build a winder, but not yet all parts, so did test here some D things.
I admit, the D is quite a interesting technology.
Old 11th December 2017, 06:58 PM   #69
globalplayer is offline globalplayer  Germany
globalplayer's Avatar
Originally Posted by amix View Post
I can not really help you <snip>
+1 for Sure AA-AB32313 (MkII) + Meanwell.
Old 12th December 2017, 01:17 AM   #70
^ I probably know why he didn't like the 48V supply.
I played with the supply voltage.
It sounds nice smooth and relaxed at 36 V.
When I increase the supply voltage to 40 V it begins to sound a little more harsh/bright.
Still very very good but not that smooth like at 36 V.
what D amp give best sound.Hide this!Advertise here!
Does anyone with a high level sound science background want to give me the words to ag8908 Multi-Way 24 13th April 2014 02:24 AM
High end sound - does any specfic approach give up the goods more than another? Racket Scientist Multi-Way 46 31st August 2010 05:49 PM
Can someone give me informs about Cyrus amplifiers sound quality destroyer X Solid State 11 20th July 2006 02:52 PM
Can anyone give more info on this amp? mg16 Tubes / Valves 6 8th May 2003 12:43 AM
What PSU will give the best sound for an Ono (regs) ? Blitz Pass Labs 0 23rd February 2003 02:27 PM
