what D amp give best sound.
Old 10th November 2016, 03:36 PM   #21
dublin78 is offline dublin78  United Kingdom
Anyway for my active system I need at least 6 amps and 86 Euro x6 plus power supplies is not cheap. Finally the power is excessive for both tweeters and midrange.
Hypex recommend 1x SMPS400A180 power supply for 6 x UCD180 modules, so you may not need 6x power supplies for your application. The mids and tweets do not need much current. Don't worry about having too many watts. Better to have too many, than too few.
Regards.
Michael
Old 10th November 2016, 03:48 PM   #22
Osvaldo de Banfield is offline Osvaldo de Banfield  Argentina
Osvaldo de Banfield's Avatar
Location: Barrio Garay,Almirante Brown, Buenos Aires, Argentina
Default What?
As a first, it would be interesting to know what do you understand as "Best sound", no?
Osvaldo F. Zappacosta. Electronic Engineer UTN FRA from 2001.
Argentine Ham Radio LW1DSE since 1987.
Old 12th November 2016, 11:43 AM   #23
ginogino is offline ginogino  Italy
Only smps1200a180 can power without limitations, 6 ucd180 modules (datasheet pag. 11 e 12, sez. outpower) , the smps400a180 can feed, 2 ucd180 modules.
Old 14th November 2016, 10:16 AM   #24
Hypex themselves stated to me that 1x SMPS400A180 would be fine for 6x UCD180. Can't get better confirmation than that methinks.
Regards.
Michael
Old 14th November 2016, 10:27 AM   #25
mhouston is offline mhouston  Australia
mhouston's Avatar
After building six or seven Class Ds and selling all but one (which I like) there are better sounding in your/my system Ds. Amps and spears are a marriage get right and you're in heaven. No need to start e the other alternative.
BUT, BUT, BUT, BUT, BUT, I would only ever employ linear PSs. And I would suggest Tripath Ds. They are beating the best SS amps around. Look out for reviews.
Old 14th November 2016, 10:29 AM   #26
mhouston's Avatar
Should add I'm about to finished some Tripath T3 150W momoblocks with 44,000uf of ultra low ESR Mundorf MLytic caps.
Old 14th November 2016, 10:47 AM   #27
kees52 is offline kees52  Netherlands
I see there a lot of investications about D amps, I had the idea when without feedback making digital a triangle signal because when it is precise and liniair the amp give the lowest distortion.
Neat a power dig to an converter.
Old 14th November 2016, 11:39 AM   #28
mhouston's Avatar
The amps I'm talking about are not digital they are switching amps. You can buy digital amp modules though.
Old 14th November 2016, 01:14 PM   #29
kartino is offline kartino  Indonesia
kartino's Avatar
UcD is the best sounding class D
I have tried many
Old 14th November 2016, 02:12 PM   #30
Yes I mean class D amps.
A triangle is used as input for modulation, this has to be a very presice signal because it has direct impact on liniarity. Making this digital with a pcocessor is maybe a way to get a low distortion class D amp, even without feedback. I have to say also that the death time is also a uge factor for distortion, use of a extreme fast mosfet is needed to get as less death time as possible.
In principle it is a digital amp, it is a power digital to analog converter with use of demodulation coil.
regards
what D amp give best sound.Hide this!Advertise here!
Does anyone with a high level sound science background want to give me the words to ag8908 Multi-Way 24 13th April 2014 02:24 AM
High end sound - does any specfic approach give up the goods more than another? Racket Scientist Multi-Way 46 31st August 2010 05:49 PM
Can someone give me informs about Cyrus amplifiers sound quality destroyer X Solid State 11 20th July 2006 02:52 PM
Can anyone give more info on this amp? mg16 Tubes / Valves 6 8th May 2003 12:43 AM
What PSU will give the best sound for an Ono (regs) ? Blitz Pass Labs 0 23rd February 2003 02:27 PM
