nobsound mo-gu drok f900 dual tpa3110 amp
Old 11th May 2016, 07:10 AM   #1
smile2 is offline smile2
Default nobsound mo-gu drok f900 dual tpa3110 amp
Cheap and good sounding amp.
I couldn't find any pictures of the inside on the internet.
My second order came in damaged, so i could take some pictures of the printed circuit.
Old 13th May 2016, 12:39 PM   #2
redkid is offline redkid  United States
Thank you for posting. I have one on the way myself.
Old 13th May 2016, 01:24 PM   #3
wwenze is offline wwenze  Singapore
That soldering...
I guess it is cheaper than having connectors
Old 5th June 2016, 03:02 PM   #4
panda360 is offline panda360  Hong Kong
panda360's Avatar
I have one, good sound with blue tooth connected. Seems I need to change 2 capacitors.
Old 5th June 2016, 06:34 PM   #5
horst303 is offline horst303  Australia
wonder which is the chip that produces that annoying voice over.
Old 8th June 2016, 05:10 PM   #6
easp is offline easp
What are the markings the chip on the lower-right hidden by the wires? My guess is that it is the Bluetooth DAC/SoC, Which probably makes it responsible for the annoying voiceover.
Old 14th June 2016, 02:36 AM   #7
Attachment 548479
Attachment 548480
with the benefit of insight is there a way to remove the case without causing damage?
Old 14th June 2016, 11:34 AM   #8
removing the case:
remove 4 screws behind the sticker on the speaker terminal side.
unscrew the pot meter.
slide out the amp board.
The other side looks the same, but you don't have to remove those ( photo )
regards jan
Old 20th October 2016, 07:00 AM   #9
patrick131184 is offline patrick131184
Does anyone find a way to disable these annoying startup/bluetooth sounds?
What Bluetooth Chip is used in this amp?
The cable on these pics is covering the model number
Old 13th March 2018, 06:27 AM   #10
wrybread is offline wrybread  United States
I just got this amp and opened it up, here are some pics. It's easy enough to open up, but you'll probably damage the sticker on the front (the one on the power switch side).
I'll probably swap out the two big capacitors, but what I'd *really* love to do is disable that heinous jingle when the unit first powers on. I can't imagine anyone thinking that was a good idea.
Another nice mod would be to add a bluetooth "connect" button. it's all fine when using it with a single device, but if you're using it with 8 devices and left one connected, it can be a task to figure out which one is connected. I don't imagine anyone knows of a way to add a bluetooth "connect" button to this amp?
nobsound mo-gu drok f900 dual tpa3110 ampHide this!Advertise here!
nobsound amp mackd88 Tubes / Valves 1 14th July 2015 11:13 PM
Drok 5V Audio Amp Wiring javy Chip Amps 18 10th October 2014 09:40 AM
New build ideas, using TPA3110 amp FranciscoPerez Full Range 4 20th February 2014 07:58 PM
my tiny class d amp tpa3110 rikvancoolwijk Class D 19 24th August 2010 03:40 PM
bias adjust installation, bogen mo-100a mo 100a quicksilver apehead Tubes / Valves 2 27th December 2006 02:13 PM
