TDA8950 Class-D BTL Stereo Amplifier Board - diyAudio
Go Back   Home > Forums > Amplifiers > Class D
Old 9th May 2016, 12:15 PM   #1
Exclamation TDA8950 Class-D BTL Stereo Amplifier Board
I have a TDA8950 Class-D BTL Stereo Amplifier Board from Wholesale Product Snapshot Product name is TDA8950 amplifier board dual AC24V-0-24V 2.0 channel class D NE5532 + UPC1237 + TDA8950 amplifier (with protection) 120W+120W. The board is working fine but I want to use in BTL mode. The board shows three regions with BTL mentioned and I dont know if i am supposed to short them or what. So, how do i get this board to operate in BTL mode?BOTTOM.jpg
Old 9th May 2016, 12:55 PM   #2
anatech is offline anatech  Canada
anatech's Avatar
Hi cRash1001,
Have you asked the vendor for that information yet? There should be an instruction sheet for it. Often they are folded up in the box.
-Chris
"Just because you can, doesn't mean you should" my Wife
Old 10th May 2016, 03:14 AM   #3
hi anatech,
There was no instruction sheet no nothing.
Old 10th May 2016, 06:05 PM   #4
hi cRash1001
i think should soldering 2 resistors on "BTL "mark.and input signal should be on "circle BTL" mark ,but i am not sure.
if take a picture of the other side of the board ,i can guide better .
Old 10th May 2016, 10:39 PM   #5
LuigiDJ is offline LuigiDJ  Colombia
LuigiDJ's Avatar
This is the datasheet for that chip amp:
http://www.nxp.com/documents/data_sheet/TDA8950.pdf
You could follow the traces to the chip and connect it like the image.
I too bought one of these amps and I'm waiting for it to arrive from china, I'll post some more when i have it.
Old 14th May 2016, 02:38 AM   #6
I traced the path of the traces and turns out I needed to short the ones that have BTL written on PCB. The one with BTL and circle , I have no idea what it does. The audio quality is quite nice and the distortion is only noticeable at very high volumes.
Old 5th June 2016, 07:24 PM   #7
LuigiDJ's Avatar
My tda8950 arrived this week and it works very nice. It is being powered by a 22-0-22 Vac 10A transformer. It came with the BTL markings on the bottom side, and it follows the typical application circuit. The lines have to be shortcircuited and the BTL circle becomes the input, the volume control doesn't work in this mode (at least according to this circuit, if I followed it correctly).
It doesn't have SMD components (besides the ic) so replacing or upgrading things should be easy. It comes with 2 x 3300uF/50V filter capacitors and a KBU1010 bridge rectifier, i'm thinking on upgrading the filter capacitors or removing them at all and use an external power supply with bigger filters.
Right now it drives 1 x 12 inch speakers by side and it sounds nice and loud.
Sure Electronics New Tripath Board 4*100W class-D Amplifier Board 7788q Class D 353 22nd February 2017 06:29 PM
2x 85W TDA7294 BTL+Speakers protected Amplifier board Paladinxxx Swap Meet 1 16th March 2014 02:43 PM
DIY Hi-Fi Stereo Amplifier Board Amp 2 Channel TDA7294 BTL + Speaker Protection mit Chip Amps 1 7th February 2014 04:20 AM
LA4743B Car stereo BTL 4-channel (45 W x 4) power amplifier IC emuman100 Chip Amps 2 15th March 2004 07:21 AM
Copyright 1999-2017 diyAudio
