full differential UcD modulator with extra integrator
Old 7th June 2017, 05:24 PM   #71
Sous is offline Sous  Ukraine
This is just the simplest version. Since the network already has a service manual for "nc 400" you can see the circuitry there.
The fully differential modulator worked well, but the implementation of the PCB made the assembly very laborious.
I simplified new device as much as possible.
Old 21st June 2017, 06:17 PM   #72
First prototype
Old 22nd June 2017, 01:38 PM   #73
Erica.C is offline Erica.C  China
Originally Posted by Sous View Post
First prototype
Very neat design, thanks for sharing!
and, how is the output power for 8ohm load?
Old 23rd June 2017, 10:11 AM   #74
Thank you very much Erica!
Power is limited by output transistors.
Service step-down stabilizers can operate up to +/- 90V.
I think 200W at 8Ohm should be for IRFB5615
For IRFB4227 it will be necessary to increase dead time, I did not try.
Old 26th June 2017, 04:30 PM   #75
Agree
Yes, i want to know the working range of the dc-dc convert to support the gate driver circuit,
Also, i had try to build the amp with the IRS20957 plus IRFB4227, the dead time setting to 25ns, with the regualted power supply(daul 90V) to get 450W output for the 8ohm load! This IRFB4227 is very good MOSFET.
Old 16th July 2017, 06:43 PM   #76
Workhorse is offline Workhorse
Workhorse's Avatar
Originally Posted by Pafi View Post
You have 1 comparator with 1 output signal that is duplicated later. You can call it differential, but it doesn't have any benefit over the basic circuit. Contrary to your design it is possible to use 2 different modulators that carries different informations and can be used to suppress unwanted modulation artifacts. That would be fully differential in my terminology.
You mean 3 level PWM ?
Old 17th July 2017, 12:36 PM   #77
kartino is offline kartino  Indonesia
kartino's Avatar
So workhorse still alive
My discrete UcD has fully differential.
Check my thread.
Old 17th July 2017, 12:55 PM   #78
Workhorse's Avatar
Check my thread.
Well that is 2 level PWM we usually call it AD mode. The 3 level PWM which is BD mode is in true sense fully differential IMHO.
Though, one can call the 2 level PWM AD mode as balanced input and bridged output for sure
Old 17th July 2017, 01:19 PM   #79
kartino's Avatar
You are right.
Do you have any topology description for reference for class BD?
I am thinking to make it.
Old 17th July 2017, 02:07 PM   #80
kartino's Avatar
Hi Sous,
I am very interested by your design, just realized that it is something new for me.
In my country it is hard to find good parts and smd. I am thinking to make it very low cost. As always, I make pro sound. All are full in my mind now.
full differential UcD modulator with extra integratorHide this!Advertise here!
UCD Based Fully Differential Full Bridge 450W RMS Amp classd4sure Class D 91 3rd June 2017 08:51 AM
A self oscillation differential full bridge D-amp based on UCD topology QuantumTunnel Class D 2 16th March 2015 11:02 AM
Anyone tried a UCD topology as a high level modulator for radio? dmills Class D 5 6th May 2013 06:11 PM
12B4 PP Full Differential Amp Notion Sheldon Tubes / Valves 8 21st May 2008 01:12 AM
Full bridge UcD Help, not work witali Class D 2 24th March 2006 01:34 PM
Copyright ©1999-2017 diyAudio
