TPA3255 - all about DIY, Discussion, Design etc.
Old 17th July 2018, 03:44 PM   #751
doctormord is offline doctormord  Germany
doctormord's Avatar
What i mean is, that i can't see any through-soaked solder at the vias coming from the powerpad at the other topside.
TPA3255 - all about DIY, Discussion, Design etc.-fx502spro-disassembled-heatsink3-jpg
Old 19th July 2018, 09:07 PM   #752
irs20957 is offline irs20957  Russian Federation
Testing my LLC PSU and amp TPA3251
Old 20th July 2018, 05:52 AM   #753
chermann is offline chermann  Austria
hi doc
yes this is correct i remember ...no soldering soak through this holes.
tpa3250....fx502spro
is it possible to rework (solder) this easy? i guess not....
Old 22nd July 2018, 08:56 AM   #754
Cradle22 is offline Cradle22  Germany
Cradle22's Avatar
Hi!
I am in the process of building a six channel TPA3255 amplifier (three "chinese" tpa3255 modules with three switch mode supplies).
I would like to use a speaker protection and turn on delay module.
I have some UPC1237 stereo protection modules at hand, however, they use a common ground between the left and right channels.
Is that ok for the bridged stereo TPA3255 module, or will I have to use seperate modules for each channel?
Thank you,
Arndt
A Sacrifice For Freedom
Old 22nd July 2018, 09:32 AM   #755
sybic is offline sybic  Poland
I used a trivial system
Old 22nd July 2018, 10:43 AM   #756
Cradle22's Avatar
But I already have four of those modules, bought especially for my setup.
The big SMPS is for an additional IRS2082 subwoofer amp... I need to fix a bent cap, so it is not mounted right now.
Old 22nd July 2018, 03:00 PM   #757
Hi Sybic
you wrote nichicon fine gold if i remember but..
Which input caps do you use?
Did you try different types, brands?
thanks
chris
Old 22nd July 2018, 03:25 PM   #758
In this system, I have not tested others.
Old 22nd July 2018, 03:38 PM   #759
thanks for your quick response.
If i look at the TI LC Guide.....Your output filters are 10 but 680nF
is it a compromise for 6 ohms?
Old 22nd July 2018, 04:36 PM   #760
exactly, 680n is at 6 ohms.
I assumed that for 8 and 4 there will be a compromise OK
1uF I have only for L and R channel
TPA3255 - all about DIY, Discussion, Design etc.Hide this!Advertise here!
Inexpensive HDMI 2 channel receiver design discussion brw02005 Construction Tips 1 6th March 2016 07:27 PM
A Discussion on Design Philosophy - OB vs Multiway vs NOB miragem3i Multi-Way 2 10th July 2014 03:02 AM
Discussion: push pull design and minimal distortion does it matter ? hoppaz Subwoofers 19 15th November 2012 08:34 PM
Car subwoofer (2x8" fancy design discussion) VEC7OR Subwoofers 11 29th May 2004 09:12 PM
