Class D vs Class AB
Class D vs Class AB
Old 17th February 2016, 07:29 AM   #11
tonitonitoni is offline tonitonitoni  Croatia
i find tas5630 modules are a lot better sound than 3116 ,even on same laptop psu. more expensive yes but lot better
Old 17th February 2016, 01:43 PM   #12
Pafi is offline Pafi  Hungary
There are many different 3116 modules with very different component quality and PCB layout...
Old 17th February 2016, 03:10 PM   #13
there is lot different 5630 boards too,but all 5630 seem to sound better to me.
Old 17th February 2016, 03:33 PM   #14
ravpreet420 is offline ravpreet420
I think in professional sound
AB=high
H=Mid
D=Low
Old 17th February 2016, 04:58 PM   #15
I repeat: many different 3116 modules. Some of them are proven to be a faulty design, some are audiophil upgraded. If you didn't check them both, how can you judge them generally? It's impossible to qualify them in the same group.
5630 is a different question.
Old 17th February 2016, 04:59 PM   #16
xrk971 is online now xrk971  United States
Got Foam?
xrk971's Avatar
Class D vs Class AB
Most pro sound amps are now class D. All major line array installations have class D amps built in. The savings in efficiency is huge as you don't need as big of a power mains when trying to get 50kw or 100kw of power out to the stage.
I use both class D and class AB. They both sound good when done well. My recent experience with a DIY class AB (Dx amp) that I assembled myself has surprised me with how good it sounds.
A good 3116 or 3118 may not be able to match the ultimate low HD numbers on the top class AB's, but then who can hear the difference between 0.1% THD and 0.0001%THD when the speaker is typically no better than 0.3%THD?
But at $4 or $9 or $15 for a class D amp, you have nothing to lose to try it out. If you haven't listened to a Sanwu "blue" TPA3118D2 PBTL monoblock, you are in for a treat. At $8 ea, it is one of the supreme audio values out there.
$20 to $40 IRS2092 200w amps are also very very clean sounding with exceedingly low THD.
I must have 30 amps class D and class AB, so it's fun - like tasting cheese and wine. They have little nuances. In the end, my daily use amp are two TPA3116 Ybdz with OSCON's and bootstrap snubber mod.
My second go to amp is the TDA7498 100w with 24v SMPS PS
My third go to amp is the Sanwu 3118 PBTL or a TD7298 class AB lunch money amp.
But now starting to use LM3886 and my new Dx amp - really liking the highs and the bass on them. Mids not bad either, need more critical listening.
Here is a photo of my new Dx amp running on two 19v SMPS bricks for dual rail:
vs my Sanwu 3118 PBTL (4 channels x 60w):
Old 17th February 2016, 05:37 PM   #17
Bare is offline Bare  Canada
Originally Posted by Lo_Tse View Post
Sound perception is a personal thing. I would suggest get one of those cheap 3116/3118 amp boards that have received decent user feed backs and tried it out yourself. These amps are so cheap and can run off a lab top brick. Find out yourself first hand.
Did exactly that.
Got the Blu Black YJ version so loved by the Forum.
It proved as a complete failure.
Huge (fightening) On/ Off noises and an unresolvable ever present hiss.
The thing is in the parts box, a stop over point on it's way to the dumpster.
And yess.. I had some small familiarity with Chip amps over the past few years, having point to point DIYed one and even own a YJ ta 2020 board which is actually quite decent.
Caveat Emptor Kids just cuz it's widely babbled about, it doesn't actually follow that it's as claimed... at least every time.
Old 17th February 2016, 06:18 PM   #18
i am sorry i dont dig "audiophile" components,this thread being clasd vs ab is very general so i am saying my general experience. have tried few failed and few very good implementations of 3116 ,always had bad sound and everyone could recognize that class d is playing, on other hand 5630 i managed to fool few trained ears into thinking its regular amp playing on mid/high channels. so yes i used 5630 from 50w/channel to 300w/channel for small bins and only have words of good . so yes 5630 is working better overall,altough more complicated pcb,so thats different one is working other is not power and complexity aside
Old 17th February 2016, 08:27 PM   #19
ssportclay is offline ssportclay  United States
Originally Posted by mscrgn View Post
Which sound is better quality class d or class ab? Pls help i deal only with class ab i want to know if class d sound better thanks
All of my class AB amplifiers are quite a bit better than my class D amplifiers. A good budget commercial class AB amplifier to try is the Emotiva miniX. Its a steel whenever it goes on sale.
Old 18th February 2016, 02:07 AM   #20
Lo_Tse is offline Lo_Tse  Canada
Originally Posted by Bare View Post
Did exactly that.
Well, that YJ blue/black was actually the worst of the bunch of 3116 that I tried. Even the first YJ red board sounded better. I bought one, listened it for 5-10 minutes and put it away. My original plan was to mod it but I decided it was not worth it. By the way, there are at least two versions of this board. The noise issue that you experienced was most likely due to poor implementation (crappy parts etc.).
I have better luck with other two 3116 boards (the Audiobah green and the SMKN) that I bought. I have compared them side by side with my Bryston class AB amp. At typical listening level, the differences in sound is small and the 3116 boards were very enjoyable. Noise is not an issue and no pop when turn on/off. I do not know what kind of PSU you used. My experience was that some SMPS causes more noise than others.
I am sure that the owners of the Ncore will say that their class D amps kick butts
Class D vs Class ABHide this!Advertise here!
Class-AB meets Class-D: Yamaha's EEEngine Topology - where are this Diy Projects? tiefbassuebertr Solid State 75 3rd December 2016 06:49 AM
Leaving class A how to make this amp leave class A to AB when volume is increased? rhythmsandy Solid State 3 14th June 2016 01:16 AM
Contest: Linear Power Amp in a mint tin (class Aa, class AB, or class B) danielwritesbac Chip Amps 206 19th January 2013 08:52 PM
does class A amp feel more powerful with same ratings compared to class AB? rhythmsandy Solid State 7 10th December 2012 05:21 PM
Can a Class AB PP amp be said to be operating in Class A at low signal levels? ray_moth Tubes / Valves 19 23rd January 2009 07:52 PM
