Low power consumption reference amp - diyAudio
Go Back   Home > Forums > Amplifiers > Class D
Old 1st November 2015, 11:20 PM   #1
Default Low power consumption reference amp
I would like to build a studio/mixing setup on a small sailboat.
Everything will be running from 12-volt lead acid batteries, charged by solar. We don't have a lot of capacity, so I want the power consumption to be as frugal as possible.
Can anybody recommend a D or T amp that would be a good choice for running a pair of near-field monitors?
- 12v DC supply, obviously
- Best possible flat frequency response and low distortion
- Modest power output is fine
I see a few likely candidates out there such as Tripath TA-2020 or TA-2024 but was wondering if there is something else on your radar.
Thanks - !
Old 2nd November 2015, 01:10 PM   #2
Given the 12V SLA, you can expect about 10W @8Ohm of undistorted output power in BTL configuration . All suitable class-damps will give similar output power at given supply voltage an load impedance. You better look for low standby current consumption to extend battery life.
And for high efficient, water-proof speakers.
Old 2nd November 2015, 02:15 PM   #3
MaxAmp20 would be the preferred option. Second best would be the TPA3116 in 1SPW mode in my opinion.
2A3 se amp power consumption sri07174 Tubes / Valves 5 28th March 2015 02:22 PM
Ultra Low Noise and Low Power Consumption OCXO ULNOCXO Vendor's Bazaar 21 6th July 2014 10:39 PM
The extremely low energy consumption hints/tips/projects thread. freax Everything Else 22 22nd December 2012 05:16 AM
Power consumption Viper_user Solid State 5 12th March 2012 11:41 AM
Power consumption Zanthus Full Range 10 19th September 2010 01:01 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
