ICEpower 200ASC ground connection - diyAudio
Go Back   Home > Forums > Amplifiers > Class D
Old Yesterday, 05:26 PM   #1
Default ICEpower 200ASC ground connection
I need your advice on ground connection idea for my recently bought ICEpower 200ASC module. I'll be using it as DIY monoblock power amplifier in full balanced configuration and the problem is that I have limited idea on where to connect ground to metal chassis. Basically there are 3 ground connections possible to make ie. module ground point, mains plug (earth) and signal ground PIN1 of XLR connection. While I'm quite certain that GND must be connected to chassis at module point and mains plug side I'm not sure of connection at XLR plug. To make things even more complicated I've seen in other ICE models designing manuals that XLR PIN1 should be connected to chassis anyway but I think with all 3 ground connections a ground loop will be created.
Could you advise on best solution, please. Thank you.
[FS] ICEpower 200ASC + ICEpower 200AC sipsik Swap Meet 23 20th May 2015 08:05 PM
Icepower 200asc bcabral Subwoofers 6 24th December 2013 05:12 PM
ICEpower 200ASC's non functional Daytona50 Swap Meet 2 23rd June 2013 06:17 PM
IcePower 200ASC marcosreg Class D 1 11th October 2010 07:31 PM
Need one ICEpower 200ASC modules thim Swap Meet 1 14th February 2009 03:48 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
