soundstream xxx6500d no relay - diyAudio
Go Back   Home > Forums > Amplifiers > Class D
Old 7th October 2015, 11:43 PM   #1
Default soundstream xxx6500d no relay
hi i am working on a soundstream xxx6500d and the relay does not engage.
If i connect the speaker before the relay i get clean audio.
Does anyone have a schematic for this amp.
Any help will be much appreciated
Old 8th October 2015, 12:44 AM   #2
DjLeco is offline DjLeco  Romania
Send a message via Skype™ to DjLeco
The relais doesn't do the "engage click"?
If it do, and no output, the relais contacts can be dead.
Old 8th October 2015, 03:18 AM   #3
Thanks for the reply.
There is no clicking of the relay.I have traced it back to pin 4 on the driver card but i dont know where to go from there.
Old 8th October 2015, 09:58 AM   #4
Make a shortcircuit between Base ans Emitter of Q3 (red circled one in left side).
If engages check other components around it, if not engages, R11 (10 ohms) could be open circuit, and maybe diode DP5 could be shorted.
Make another test, with volume set to minimum (no signal on input), check with one DC multimeter if before relais (where U got clean audio), if is present any continuous DC voltage between output and GND.
Write here what U have measured.
Or simpler, again with no signal on input, if connect speaker and you have some DC there the voicecoil must go out or in speaker chassis.
Old 8th October 2015, 02:42 PM   #5
If i short the collector and emitter of q3(d600) the relay engages...there is no movement of the speaker cone.If i measure it with reference to speaker ground i get 0.015 volts dc.
Old 8th October 2015, 02:56 PM   #6
JonSnell Electronic's Avatar
If the remote is faulty or stuck in mute, remove (temporarily) D7 to override the mute function. Most stay muted until signal is received.
Support for PMC DS-001, (Hypex) UcD400,Valve Equipment and designs both new and old. www.jonsnell.co.uk
Old 8th October 2015, 04:58 PM   #7
Emmiter to collector, sorry for mistake.
Old 8th October 2015, 06:59 PM   #8
Removed d7 and still no relay.
Old 9th October 2015, 03:12 AM   #9
I just pulled and tested everything as per schematic above.Everything tested ok.
Anything else i should be looking at?
Old 9th October 2015, 04:32 AM   #10
Check the bases voltage of Q3 and Q5. It should be positive to enable the relay.
Soundstream D200 Relay Substitute Help dodgerblue Car Audio 2 17th August 2011 09:35 PM
Soundstream USA204 razirafi Car Audio 28 27th September 2007 07:30 AM
Soundstream shaolinfox30 Car Audio 1 24th July 2007 10:03 AM
soundstream 6.0 ben04srt Car Audio 10 11th March 2007 05:56 AM
Soundstream? thylantyr Pass Labs 6 10th November 2006 09:35 PM
Copyright 1999-2017 diyAudio
