TPA3251d2
TPA3251d2
Old 18th July 2015, 11:43 PM   #21
doctormord is offline doctormord  Germany
doctormord's Avatar
TPA3251d2-tpa3251d2_5_960-jpg
Needs some 3.5mm jack..
Good night.
Old 19th July 2015, 01:06 AM   #22
Lo_Tse is offline Lo_Tse  Canada
Good night.
Very nice locking mock up picture!
Old 20th July 2015, 06:09 PM   #23
Nisbeth is offline Nisbeth  Denmark
Nisbeth's Avatar
TPA3251d2
If you can pull that off let me be the first to shout "group buy"!
/U.
DIY projects blog
Old 21st July 2015, 02:58 PM   #24
doctormord's Avatar
I guess so, schematic is finished.
Old 21st July 2015, 03:32 PM   #25
gmarsh is offline gmarsh  Canada
gmarsh's Avatar
Any chance I can have a peek?
Old 21st July 2015, 03:35 PM   #26
jean-paul is offline jean-paul  Netherlands
diyAudio Moderator Emeritus
jean-paul's Avatar
Good night.
Hi, why a 3.5 mm jack ? For headphones or, heaven forbid, for the inputs ? Worst connector since ages, alway bad contacts and crackling. I replaced so many of them that I never use them in my own designs.
edit: just checked your web page and it seems you use them for inputs. Bad choice compared to RCA. Sorry. Using RCA is standard and RCA to 3.5 mm cables can be bought. It would make your design way more user friendly, maybe you can use both ? With a power amp as this chip crackling seems to be very unwished for.
It's only audio. Member of the non modular PCB design committee
Old 21st July 2015, 03:49 PM   #27
gmarsh's Avatar
My card design is still in the planning stages.
I'm kicking a few ideas around, with the thoughts of making the card a bit more high end - I'll probably toss on a switching regulator to make +-12V out of PVCC, to power AVCC as well as a proper differential audio input stage.
Old 21st July 2015, 04:18 PM   #28
impuls60 is offline impuls60  Norway
Cool! Can't wait to see what you come up with gmarsh!
Old 21st July 2015, 05:45 PM   #29
doctormord's Avatar
Because i can.
I never had any issues for the last 40 amp boards. So maybe yours where all from poor quality or not properly used/soldered. I use them always in a self grounding configuration to mute/ground the inputs when no connection is made.
Well, even RCA is not GND before Signal when making a connection, so RCA is far from optimal as well. As my normal amp designs are made to be small and portable, i did not used RCA connectors mainly because of their size. Those amps are 50*50mm˛..
If you will have a look again, you may notice that there's normally a pinheader for an alternative input.
Millions of millions of mobiles,mp3-players etc. worldwide get stressed/stretched/used every day with lots of force on the 3.5mm connectors. Quality ones wont fail, cheap ones will.
But in the end, there will be RCA (at least) on this board.
Beside this, do you prefer an opamp differential input stage or a PNP differential amp with constant current?
Old 21st July 2015, 06:05 PM   #30
jean-paul's Avatar
GND before signal has not been the primary goal of RCA and who plugs in connectors on a live power amp ?
I have used many different 3.5 mm jacks and if the connector does not fail then the cable will. Also in mobile phones it is one of the most failing connectors with micro USB as a good second one. These connectors were not designed for high quality but for low cost. Talk to a repairman (I was one myself) and I know what answer you'll get The quality ones just last a bit longer. I am not an advocate for RCA but when do you see an RCA plug/jack fail ? Of course you can use 3.5 mm "because you can". You can also design 50 x 50 mm2 boards to keep costs low but isn't this hobby meant to get the best out of a design ? Since when is very small size obligatory ? To be able to use 3.5 mm connectors and leave out the coils ?
Just joking, I understand you only want portable stuff and thus you do some concessions but TPA3251D2 won't be for portable designs I guess.
TPA3251d2Hide this!Advertise here!
