TAS5611 power supply - diyAudio
Go Back   Home > Forums > Amplifiers > Class D
Old 2nd July 2015, 03:06 PM   #1
Default TAS5611 power supply
Hi i just brought a TAS5611 chip amp as i want to have a go at using a class d chip amp. It is for a pair of seas mimir . The question i wanted to know is how do i go about the power supply to power it can i use a 36v smps or does anyone have a idea on what i need to do
i am a begginer when it comes to the chip amps so sorry if these questions seem odd
Old 2nd July 2015, 07:58 PM   #2
JonSnell Electronic's Avatar
Send a message via Skype™ to JonSnell Electronic
You can go as high as 48V or as low as 30V and it should be fine.
Support for Flying Mole Class D, Valve Equipment and designs both new and old. www.jonsnell.co.uk
Old 2nd July 2015, 10:32 PM   #3
What kind of amperage should i be looking for or does that not matter ?
Old 2nd July 2015, 10:45 PM   #4
I would look for 10Amps at 32Volts.
Old 24th July 2015, 08:56 PM   #5
hi does anyone know where i can buy the 3 pin adaptor that is used on the input section so far i have soldered the rca wires directly on the board but i would rather get the adaptor
Old 26th July 2015, 08:38 AM   #6
my 5611 works well with voltages as low as 20v.
i guess even 12v would be ok.
Old 26th July 2015, 09:07 AM   #7
cyteen is offline cyteen  England
cyteen's Avatar
For the input connector:
If you want to make your own then search for XH2.54-3P on ebay:
XH2.54-2P 3P 4P 5P 6P 2.54MM CONNECTORS SETS - SOCKET + PLUG + TERMINAL | eBay
If you want pre-made:
Yuan Jing Audio - Shielded Inter-Connection Audio Cable JST-XH-2.54-3P AWG24 - USD $0.80 - Connectors
Old 26th July 2015, 04:07 PM   #8
Originally Posted by cyteen View Post
Thanks for the help
Is TAS5611 a good choice in 2015? TripathFan Class D 58 29th March 2016 09:42 AM
Making Symmetric Power Supply from Single with 4x ATX power Supply? lupetalo Power Supplies 11 20th November 2012 11:51 AM
TAS5611 class D amplifier JANEK555 Class D 0 23rd March 2012 06:51 PM
Power supply positive-negative-ground from a single power supply mome Power Supplies 8 9th September 2011 05:17 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2016 DragonByte Technologies Ltd.
Copyright 1999-2016 diyAudio
