4 x 50 watts for Linkwitz LXmini - suggestions? - diyAudio
Go Back   Home > Forums > Amplifiers > Class D
Old 28th June 2015, 10:24 AM   #1
jakja83 is offline jakja83  Norway
Default 4 x 50 watts for Linkwitz LXmini - suggestions?
I am about to build a pair of LXminis and since the Emotiva UPA500 is discontinued I am interested in other options that won't cost a lot, but still sound VERY good and provide enough power to drive the LXminis safely. I prefer modules og ready-made stuff over too much soldering.
Amplifier_options
Old 28th June 2015, 03:28 PM   #2
xrk971 is online now xrk971  United States
xrk971's Avatar
A pair of TDA7498's will give you 4 x 100w for ver little money. They sound quite good and are worth considering. Need a 24v power supply and you should get 50w of low distortion pipit no problem.
Old 28th June 2015, 03:30 PM   #3
Ok, and SQ will be on par with e.g. Emotiva?
Old 28th June 2015, 03:37 PM   #4
What sort of case is normally used with such boards?
Old 28th June 2015, 04:06 PM   #5
xrk971's Avatar
I don't know about Emotiva but SQ is comparable to TPA3116 which is very good as class D amps go. I don't bother with cases for DIY. But plenty of options for cases.
If you want a cased amp, better off buying a complete finished amp from China, Aliexpress, eBay, etc. you will not save any $ doing it yourself.
For example $57 complete. No way a case, knobs, binding posts etc can be made for less on your own.
http://m.ebay.com/itm/Finished-TDA74...-/120960253784
Old 28th June 2015, 04:42 PM   #6
Ok. Thanks. What I really want is a poweramp without volume etc. but I probably can just leave at full volume and adjust upstream.
Old 28th June 2015, 04:48 PM   #7
HI, sorry to deviate.. Iam on the cusp of buying 4 x Modlus 86 chip amps and driveing some LX minis anyone tried this?
cheers
Johnny
Old 28th June 2015, 05:14 PM   #8
pguerin is offline pguerin  France
Hi JOHNNYCR100,
Surely a good amp but at 260 € for only the amp PCBs I think there is a lot of alternatives.
I own a player wich has an Icepower 50ASX2 amp module inside, it sound VERY good. Why not use two pwr-ice125WD plate amp :
PWR-ICE125WD | miniDSP
Old 28th June 2015, 07:34 PM   #9
xrk971's Avatar
cheers
Johnny
That is perhaps the finest sounding amp ever at any price. If you can afford it and have time to hand solder that is great. It doesn't hurt to spend $30 for a pair of cheap TDA7498's that are 90% of the way there to get started and for tryout.
Old 29th June 2015, 02:16 PM   #10
Default thank you
hi Pgurien and xrk971...come to think of it my B and W Zepplin dock has a simular amp set up and thats fairly damm good...your on to something boys..
ta
johnny
New Linkwitz "LXmini" speakers JOHNNYCR100 Multi-Way 290 5th April 2015 05:59 PM
A simple quasi-complementary 50 watts amp gaetan8888 Solid State 85 26th July 2014 01:21 PM
is there a chip amp that will give me 50 watts of power merickrc Chip Amps 30 13th March 2009 02:09 PM
50 watts amplifier swaroopvg Chip Amps 12 4th July 2006 06:12 PM
50 watts more, single sided? psychosteve Chip Amps 4 14th September 2004 04:35 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
